Question about Dell Inspiron 6400 Notebook
Inspiron 6400, memory loss
As simple as; i turned off my laptop 2 nights ago as normal then when i turned it on again yesterday it was wiped, no history and started up like it was new. not even the wallpaper was there it asked to re register everything and loses memory each time its turned off. everything i had seems to be gone, ive not a clue what happened. john
  • 3 Answers
Sounds like your CMOS, which is the well-hidden thing on your motherboard that keeps a small bit of power going to retain date and time information when the computer is shut off. If it loses its charge (due to defect or age) it will work fine as long as the computer is on, but after a few hours will lose all ability to maintain the most essential information. This will cause the computer to boot as if for the first time. Check your time and date; also knowing your OS would help. But I suspect it's your CMOS, which can be replaced at any computer repair shop.
Posted on Aug 19, 2007
SOURCE:
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
Dell Inspiron 6400 runs for 2 hours or so then throws up a DIMM A fault
You could have a heat problem. Check the fan and heatsink and remove all dust from the fan and heatsink.
Sep 25, 2012 | Dell Inspiron 6400 Notebook
Hi, i have a dell inspiron 6400 and since yesterday when i turned it off it re-started itself on and enter directly in to the media direct express automatically.\r\ni´ve been starting it and pushing...
Hello.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
Oct 21, 2010 | Dell Inspiron 6400 Notebook
Hi, i have a dell inspiron 6400 and since yesterday when i turned it off it re-started itself on and enter directly in to the media direct express automatically. i´ve been starting it and pushing the...
turn off, as it starts to reboot tap f8 key continually and choose safe mode. from safe mode do a system restore to last restore point before problem began.
good luck
My laptop will not turn on again.
1. Remove the battery and reinsert it. Reboot. 2. Press F2 at bootup and boot is Safe Mode.
Nov 09, 2009 | Dell Inspiron 6400 Notebook
Memory stick pro not recognized any more by dell inspiron 6400
I suggest going into the control panel/device manager and removing all the usb devices.
Restart the computer and let it find the devices again. That might help.
Also--have you tried the stick in another computer just to make sure it works?
Sep 25, 2009 | Dell Inspiron 6400 Notebook
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400
How old is the battery? The battery is considered a consumable product. It really has to be replaced usually after a year or so. You may try updating your computer's bios software though to see if it will correct it. Updating this software is a bit risky and if not done correctly may further damage your system's motherboard.
Click this to see the instructions on how to run the update.
Click this to start the update. It can only be run though if the battery still has 30% charge. If you get an error during the update, you must replace the battery.
Nov 02, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
120 people viewed this question
Ekse
Clive
Clive
