Did u open it n c how does the button work n if u do can u put it up on youtube cuz im missin pieces n i need to buy them theres a video up takin it apart .
I assume you bought a PS2 game that works on your PS2 system but not on your PS3 system since a PS3 game will never work on a PS2.
Since not all PS3 systems can play PS2 games, you need to first check the model number of your PS3 system. If you look at the back of your PS3, there should be a serial number somewhere that starts with "CECH", followed by one more letter and a couple numbers (e.g. "CECHC02"). Unless the model number starts with "CECHA", "CECHB", "CECHC", or "CECHE", you won't be able to play PS2 games on your PS3.
If your PS3 can play PS2 games, then you need to make sure that the region of the PS2 game matches the region of your PS3. The region of the PS2 game can be found in the upper-right corner of the front of the box the game came in. The four regions are: "NTSC U/C", "NTSC J", "NTSC C", and "PAL".
Once you know the model number of the PS3 and the region of the PS2 game, you can tell if the PS2 game should work on the PS3. Use the following chart to determine if your game and system are compatible:
Last two digits of your PS3 model number: Playable PS2 game region 00: NTSC J 01: NTSC U/C 02: PAL 03: PAL 04: PAL 05: NTSC J 06: NTSC J 07: NTSC J 08: PAL 09: NTSC C 11: NTSC U/C 12: NTSC J
When you buy games from different countries you won't be able to play them as the discs are region locked. The games you bought are only playable in the USA. You will have to buy another copy of each game from NZ.
No, it will not be compatible. If you would like to play PS1/PS2, and eventually PS3 games, look into buying a original launch "Backwards Compatible" PS3. The model is CECHAO1. Good luck.
The usb ports on the ps2 can be used for a keybord with games like everquest online or a headset with games like socom, i'm sure there are other uses for them also but thats the only ones i can think off of the top of my head.
