Question about GE Profile PSS26NGS Side by Side Refrigerator
Not cold I actually have a GE Profile PSC23NGSB. Lights are flashing, the fridge and freezer are not cold. Tried everything in the troubleshooting manual. Nothing is working. Can't find a "showroom" button. Unplugged and plugged back in and tried a new outlet to no avail. Any help is appreciated as it is Sunday. Thanks.
  • 291 Answers
What lights are flashing,dispenser lights? Is the compressior running? fan by the compressor? or the fan in the freezer?
Posted on Aug 21, 2007
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a ge Profile (bottom freezer) refrigerator and the freezer is working but the fridge has now stopped working. Lights and controls seem to be working fine but fridge has not been cold now for two...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | GE Refrigerators
My GE Fridge is not getting cold
if the freezer is still o.k. then replace the control board located in the lower rear of the unit
Dec 24, 2009 | General Electric Profile PFSF5PJX Bottom...
INSIDE LIGHTS FLASH..NOT COOLING..NOT SHOWING TEMP
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jhjk
Oct 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Not cold
The most likely suspect is a defective WR55X10656 main control board. The board is located on rear of refrigerator and the fridge will need to be unplugged to examine it. Remove cover to the board by removing the sheet metal screws on the cover concealing the board. Examine both sides for burn marks or signs od heat or loose solder damage. If you find no problem there then we will mover to the next step. You can see a photo of that control board at both site below. Enter your model or part number in the search feature to check for those or other parts. Let me know if you need more help. Thanks, Sea Breeze
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
May 11, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
GE Profile PSS26NGS Side by Side Refrigerator Logo
187 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
