Question about GE 27831 Cordless Phone
Pulse and tone
I have an old GE cordless phone and have misplaced my manual. How can I change my phone from tone to pulse mode?
  • AndreyDudkin Mar 08, 2008
    I have lost my manual to GE 900MHz 26929 and I need to change from tone to pulse.
SOURCE:
Outgoing call does not connect when I dial the number
depends on the telephone exchange . Suggest switching to Tone signalling . MTDF - https://en.wikipedia.org/wiki/Pulse_dialing
Old technology- Pulse or Decadic Signalling - the line is broken by a relay contact or if even older a rotary dial manual switch contact - Dial a 9 you would break the line connection 9 times and send nine pulses.
Tone sends two frequency tones that encode the number that you selected and is a much faster dialing system and more modern method.
Oct 16, 2017 | GE 27906 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Oct 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
From Pulse to tone
TONE/PULSE DIALING
confirmation tone.
Aug 31, 2007 | GEH5450 Cordless Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
GE Phone Model 25881
Per the instruction manual, there is supposed to be a switch on the base (look on the back or bottom) for TONE/PULSE mode. Here is a link to the manual: http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf In the "troubleshooting" section, there is this entry: Dial tone is OK, but can?t dial out: Make sure the TONE/PULSE setting on the base is set to the type of phone service you are subscribed to.
Dec 31, 2006 | GE 25881EE3 Phone
GE 27831 Cordless Phone Logo
119 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
