Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony WEGA KV-36HS500
The pictures and tv worked fine until we moved. now when i turn it on, there is no sound, and a horazontal line in the middle of the black screen, it intensifies and then shuts off. reminds me of a sunset, can you help?
  • michael gilles Aug 19, 2007
    what or where is the vertical ic or flyback transformer? should i just replace the circit board?
Better call someone with electronics expence
Posted on Aug 19, 2007
  • 81 Answers
You may have cracked the circuit board when moving , sounds like a bad vertical circuit. look for bad connections around vertical ic or flyback transformer
SOURCE:
Turn on tv went black left line in middle horazontal
vertical circuit is out, some component failed. turn it on and when the line comes on hit the top of the case with the flat of your hand, if the line fluctuates or goes away you have a bad solder connection on the circuit board. if it doesn't make any difference when you smack it then something has failed completely. no user repairable parts inside.
Sep 24, 2014 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony kv-32hs240 turns on and after one hour
Sounds like you've got a short in your house electrical lines. Try using a surge protector (AKA power strip) between the power cord and wall outlet. If you've already got a surge protector, try replacing it.
Oct 29, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony TV not turning on!
u need to change the lamp...same thing happened to me then i bought a lamp on ebay for $75n replaced it n now it works fine
May 28, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
No picture or sound
6 blinks usually means a loss of the horizontal signal. This can be as simple as a bad capacitor or jungle IC. I'll look up your specific model, but do you intend to repair this yourself? If so, please update this and I'll provide additional details and instructions.
Dan
Mar 23, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My KV-36HS500 won't turn on it sounds like it wants to,but no picture,and standby light flashes 7 times,pauses and flashes 7 times again
The 7 blinks indicate that the horizontal deflection has stopped. This can be because the horizontal output transistor has shorted (common) or other defecive parts. If you are familiar with working inside of sets where potentially dangerous high voltages exist and can solder, let me know and additional details and instructions will be provided.
Dan
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Tv will work for 10min. or hrs. then cuts off kv-36hs500
    it blinked 6x. I unpluged the tv for 12 hrs. and it is fine. trouble shooting said it was horizontal hold overload.
    Dec 10, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony Trinitron wega KV27FV310
    Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
    Keep us posted.
    Dan
    May 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
