Question about Invoca 422955 Remote Control
InVoca 434325 the remote will not hold memory for 24 hours
0 characters
1 Points
I can not get the invoca remote to sync to my tv
If you can't find the code for your particular model, you can perform an auto search with your remote.
If you don't have the codes for an item you are trying to use your remote with, you can perform an auto search.
Manually Turn on the device you wish to program.
On the remote, press the device key for which you are searching.
Press "Prog" button once. (two flashes)
Make sure the remote is aimed directly at the device you want to control.
Press "Auto" button (one flash)
InVoca will now search through the library for the target device code in three second intervals. Every 3 seconds the remote will prompt you by flashing the light, and the remote will test the new code by attempting to turn the device power off.
The top line of the LCD display will show the device type and the second line will show the device code number as it searches.
When the targeted device turns off, immediately press "Prog" to save the device code in memory.
After you have pressed "Prog", check the other buttons, such as CH and VOL to be sure they work. If not, repeat the above steps. When the auto search is re-started, the search for the target device will begin where it stopped.
To stop the "Auto Search" press any key except "Auto"
Hope this works for you.
Jul 13, 2011 | Invoca 326348 Remote Control
Progam codes for dish network dvr
Hi I seeyour looking for remote codes for the Invoca to program to DISH Network receiver;we do not have codes for other remotes to program to our equipment. If you wantwe can help to get you the DISH remote to work your system, I will leave my e-mailfor you if there are any questions.
Nov 21, 2010 | Invoca 456068 LCD Touchscreen Remote...
I have a Vizio TV and just bought a InVoca 3 voice activated remote control. I did not see any manufacturers codes for my Vizio that I have to enter into my InVoca 3. Can I use my Invoca 3 with my...
For the InVoca 3.0 I used a Goldstar TV code for a Vizio TV.I'm not sure what the 3 digit code was but you can search Goldstar codes on theremote shown in the manual with a 2 digit code 33. You also can train it fromyou remote but I did not try that method. They might have different manualsbecause my manual has more instructions than the online version one.
Aug 17, 2010 | KNG America InVoca 3.0 Remote Control
Channels keep changing while watching TV !!!
You may have the volume on your invoca set too high and it is picking up speech from the television and misinterpreting it as commands. Check the mic level in your battery compartment and mess with the levels so that it still listens to you, but not the tv :)
You can find the manual here and check pages 53 and 58 for better views :) Let me know if this doesn't help. You may have to move the invoca unit itself to a new location that isn't in the "main blast" of the tv speakers. Best of luck mate! Cheers!
Jun 17, 2010 | KNG America InVoca 3.0 Remote Control
Need manual for invoca 3.0 remote can anyone help
just google invoca and go to the manuel
then just print it thats what I did for the one I bought for $0.85
Dec 28, 2008 | Invoca 326348 Remote Control
Invoca 422955 Remote Control Logo
27 people viewed this question
Top Invoca Remote Controls Experts
Electro Med Services...
Tom Chichester
Are you an Invoca Remote Control Expert? Answer questions, earn points and help others
