Question about Hitachi 60UX58B 60" Rear Projection Television
BLACK SCREEN WITH SOUND
I HAVE A HITACHI 60UX58B THAT WENT BLACK.THE SOUND COMES IN FINE AND THE ON SCREEN MENU ALSO COMES ON ALONG WITH THE MAGIC FOCUS.IVE TRIED DISCONNECTING IT FOR A DAY AND CHECKED ALL CONNECTIONS BUT NO VIDEO.CAN ANYONE PLEASE GIVE ME A CLUE ON WHAT MIGHT BE WRONG WITH MY TV.
  • PERO Aug 21, 2007
    my tv is connected to satelite through rca cables.i can hear the programming but cannot see nothing on the screen.ive also tried connecting my cam corder into the input#3 and have the same issue.thank you for your responce.
  • PERO Aug 23, 2007
    MIKENJ1964,thank you much for your help.I had a tech come out to look at my tv and the problem was the video processing unit.he did state he would need a rebuilt kit for it because this part is no longer available.parts will be about $200+labor.thanks again for your experteez.
  • 398 Answers
Is the TV connected to cable? Is there a cable box? Is it connected to a satellite box? How is the signal connecting to the TV - the F connector, the red,white,yellow, red,white,,s-video or component RCA jacks? If you can see the onscreen menu then it usually indicates that the TV is working fine and the problem is with the signal into the TV.
Posted on Aug 21, 2007
  • Mike Longo
    Mike Longo Aug 22, 2007
    The next thing to try is to go into the TV's menu and make sure that the brightness and contrast are set normally. If those are set too low then you might have no video but the on-screen menu will work. If the brightness and contrast settings are normal but you get no picture at all, there is something wrong with the video processor circuits, and that must be repaired by a qualified tech familiar with projection TVs.
Vertical position does not work on remote. Magic focus on green goes half way stops then number five comes on screen. Hitachi 51inch rear projection tv
Magic focus on a Hitachi only adjusts at 16 points on the screen and needs to be done in a dimly lit room. Frankly its a sales gimmick, the number 5 means one of the sensors inside the screen for the Magic focus is not connected or bad.
Go into the tech mode for convergence with the original remote (that menu is called the Decam mode) and see if convergence will adjust there. There are close to 120 points that can be adjusted there as opposed to less than twenty in the magic focus mode.
Dec 23, 2012 | Televison & Video
My Hitachi 60UX58B 60 in. TV was on, popped, turned blanck and now won't turn on. Checked the fuses and everything looks fine. Any suggestions?
Youre in luck. This is a very common problem and an easy fix. Goto TvRepairKits.com to get the parts and repair instructions.
Feb 18, 2010 | Hitachi 60UX58B 60" Rear Projection...
I HAVE A HITACHI 60UX58B REAR PROJECTION TV. WE WERE WATCHING TV AND THE TV MADE A POP NOISE AND THE PICTURE WENT OUT. NOW THE RED POWER LIGHT WILL NOT COME ON.
Power board is dead,know how to solders?Replaced those capacitors that puff up or burst open.Or buy a whole refurbish power board at Shopjimmy.com,Ebay.com.
Jan 26, 2010 | Hitachi 60UX58B 60" Rear Projection...
I have a hitachi 60UX58B. It went pow.
If it is totally dead, then this is likely a power supply issue. If the front panel LED comes on, but nothing else, perhaps there is a problem on the deflection board, or perhaps the convergence chips died and shut down the set.
Oct 10, 2009 | Hitachi Televison & Video
Describe your Hitachi 60ux58b Problem - Now power to unit. Picture went out, and heard pos. Figure projection bulbs, but no power?
Jul 12, 2009 | Hitachi 60UX58B 60" Rear Projection...
Sound, but black screen
you have lost the video, either because the vertical section or the deflection circuit stopped working. if the power supply is independent from the others circuits is going to work and the video does not
Aug 06, 2008 | Hitachi 32UDX10S 32" TV
HITACHI 60UX58B
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jan 13, 2008 | Hitachi 60UX58B 60" Rear Projection...
Screen distortion
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 16, 2007 | Hitachi 60UX58B 60" Rear Projection...
Big screen tv
Check C702 near flyback xformer--if shorted, relace w/3KV cap.Example==102K/2KV replace with 102K/3KV SONY # 1-161-754-00.
Sep 28, 2007 | Hitachi 60UX58B 60" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
