Question about DeLonghi DCM485 Coffee Maker
Delonghi dcm 485 power on but will not brew
I have had my Delonghi dcm485 for about 8 months and it now will not brew. In the manual it shows that when all the bars are showing it needs to be reset, thats not the problem. I've tried resetting anyway and that doesn't work.
  • 5 more comments
  • Anonymous Nov 05, 2007
    Delonghi DCM485 coffe maker also about 8 months old and suddenly no longer brewing coffee. Cleaned everything and no help in manual. Any ideas?
  • Anonymous Feb 28, 2008
    will power on but not brew and yes, it is clean
  • potr Mar 15, 2008
    My delonghi dcm485 will just stopped working even though the power is on. I can not clean it as suggested because no water is being sucked from the reserve tank to either clean or brew. I have also tried reseting to no avail.
  • chuck203 Jul 10, 2008
    Mine is about 18 months old (out of warranty). 2 days ago it worked fine. Yesterday the light went on but no brewing!
  • rmoncks Sep 24, 2008
    have power to the coffee pot but the coffee will not brew, no water being pumped out of the reservoir
  • Anonymous Oct 04, 2008
    My pot will turn on but it will not brew, nothing happens. Of course my warranty has run out. Should I just throw the coffee pot out.
  • jhbmcunn Mar 21, 2009
    Ok, my Delonghi DCM485 stopped. It won't empty the resevoiur, it won't start the brew, just nothing. I've taken it apart, the fuse (I'm guessing this is the thermal fuse (circular ceramic shape attached to the heating unit) showed 0 ohms across, so I am assuming that it is good. My heating element shows about 16 ohms across it, so I'm guessing here that some resistance is better than nothing. My pathway from the input and the out put of the element is clear. There isn't a pump unit in mine just an output to the top of the brewer. So my question is, what should be showing across the element? More resisitance? My guess at this point is, since this thing doesn't use a pump unit, it relies on heat to cause the water to rise to the top of the brewing unit, and without the heat, no brew. Any insights would be helpful, as I never made it through Delonghi service school..
THANKS "Guest" - you just saved me $100 !
I had already bought a new coffee maker (Krups) when I came across your post.  The thermal fuses (there are two of them) are indeed hidden - they are right underneath the metal braces/clamps that push them against the heating element that they are meant to monitor.  If you take off these clamps and pull back the white insulation you can easily replace the fuse(s).  What you need is:
- volt meter
- needle-nose pliers
- Radio Shack thermal fuse 228C (catalog #270-1321) - these are rated at the same temperature and look fairly identical.  They cost $1.69 at your local Radio Shack
You do NOT need a soldering iron.  So: - take off the bottom of the coffee maker - take off the clamp(s) and pull back insulation. - put your volt meter on either side of the fuse and check for continuity.  In my case, one had no resistance (good) and the other had no connection (bad). - take your needle nose and pry open the clips on the end of the wires that connect to the bad fuse ... put in the new fuse (make sure the polarity matches ... just in case) and scrunch the clips together again - replace everything
In order to make this easy to do, I disconnected the water intake/outtake and also removed the two screws holding the whole heating assembly.  Made it a lot easier
Posted on Apr 22, 2009
  • NWVinTexas Jan 24, 2011
    I toasted this morning to you Dorito88 : ) You saved me a ton of money
  • fjd3 May 20, 2011
    Dorito88 -
    It works - it makes coffee - you ROCK.
    I just went in and replaced both fuses - don't own a volt meter - never done anything like this before.
    BANG - fixed.
    Thanking you.
My dcm485 turns on but won't brew coffee and it is not that it needs cleaning. On mine, this component has failed:
http://www.datasheetcatalog.com/datasheets_pdf/S/F/2/2/SF226E.shtml
Bypassing this part allows you to make coffee - but its likely that the pot will overheat, melt and catch fire without it (unless you stand there and manually turn off the pot as soon as its finished).
Also, this may have failed because another part failed.
Posted on Mar 18, 2008
    Problem Solver:
  • 5 Answers
Have you cleaned the unit?
Pour hot white vinegar into the water reservoir and lid. Rinse out and try to run again.
Posted on Feb 09, 2008
SOURCE:
When i turn on my delonghi magnifica pronto on its says insert brewing unit but its already in plus it makes a really loud noise when i turn it on
Sounds like the brewing unit, or infuser, has not been properly seated into its holder. Are you sure that the two red retainer fittings are in their snapped out positions? See page 16 of your owner's manual.
If the infuser has not been properly seated it could cause a loud noise when the servo drive tries to raise the unit into its brewing position.
Sep 04, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi BCO330T won't heat or brew on coffee or expresso side. Burner won't heat but power is getting to the machine. 17 months old, out of warranty.
Delonghi BCO330T, this is my third one and it has the same failure. It is a know problem and the answer is they don't care
Apr 06, 2014 | De'Longhi BCO330T Combination Steam...
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
It will no longer brew. at all. I bought it as a Christmas gift, so we've only had it about 6-7 months! It will not brew, but the power light comes on.
The manual is available here:
http://web1.dlservice.org/dlservice/ext/delonghi/libretti.php?rec_a=2&rec_b=&rec_c=6
You have to click on your specific model under "Combi" and then pick the "GB" attachment for the english version of the manual,
Hope this helps! Mike, The Bean Man
Jun 13, 2011 | DeLonghi ® Combi CoffeeEspresso Maker
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
Have a delonghi dc78tc coffee maker and have power but it will not brew any suggestions
Try replacing the element. What is happening is is that the element is not getting hot enough to pull any water from the tank and heat it and send it up through the shower head to brew the coffee. Sometimes it can be a thermostat but more than likely it is a heating element.
Oct 28, 2010 | DeLonghi Caffe Elite DC78TC Coffee Maker
Delonghi Magnifica After heating up, Unit kicks off and readout says "insert brewing unit", Tried cleaning no result
Husband suggests that could be coming broken off the brewing unit as it should be activating, He suggests you should get in contact with your local De'Longhi Service Centre (should be info on how to contact in your User Manual, or google De'Longhi for your country).
May 18, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
My DeLonghi DCM485 coffee maker will not brew coffee. Cannot find any troubleshooting to solve it. Help
The same thing happened to me....At least you got three years out of yours, I got three months.
Aug 09, 2008 | DeLonghi DCM485 Coffee Maker
DeLonghi DCM485 Coffee Maker Logo
2,535 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
