Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Dishwasher soap dispensor not opening at all and tablet is dry now where before it was a mushy soloution have cleaned all round dispensor and cleaned all filters and can here water flowing in to dishwasher
  • S427k Nov 07, 2008
    Had same problem - had the solenoid tested and found was broken. Had to buy complete unit - now works well.
  • 641 Answers
I don't understand if you already solved your problem or you still looking for an help.
Posted on Aug 22, 2007
SOURCE:
Why soap dispensor does not open to let soap out
Make sure the latch is very clean and not clogged up, use an old toothbrush or similar to give It all a good clean.
Dec 17, 2014 | Dishwashers
Why will the soap dispenser not open up ?
Does it open by itself during a cycle when there is no tablet inside? Have you changed to a different tablet recently? Some tabs are larger than intended for some machines and so put pressure on the lid and stopping the catch from sliding away and releassing the tab. Or it possible that the solenoid valve that operates the dispensor is faulty, Does the rinse aid still dispense?
Sep 20, 2014 | Maytag Dishwashers
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
Lsoap dispensor wont open during wash cicle
Hi! Most washing machines have some safety regulations that include opening the soap dispensor, this is why you should put the sufficient amount of soap before the process begins. There's nothing wrong or broken to your dishwasher, this is how these machines are made. I hope this will clear your problem. Have a nice day!
Sep 01, 2011 | Whirlpool Dishwashers
Soap dispensor door won,t open
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jun 12, 2010 | Dishwashers
Doesn't clean well. Leaves dirt, etc on dishes.
this is not a lack in the machine but it sounds like you are not using soap/tablets. if you are using soap switch to tablets (such as affresh) and use a rinse agent (like jet dry). good luck with this problem! hope this solution works
Feb 17, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
Soap dispensor will not pop open
Hello. Some dishwashers have a fairly simple soap dispenser, while others have a complex one with linkage, and bimetal strips. That said, I want you to begin by thoroughly cleaning your cup with very hot water and a toothbrush so that you remove every trace of old detergent. The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
Nov 18, 2009 | Office Equipment & Supplies
Soap won't dissolve in dishwasher
I had the same problem and my wife fived it by unsticking a valve to the left side of machine in front lets water in she poped it open and dried soapm came out restarted and now works fine.
Jul 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Soap dispensor door opens, but powder soap mostly stays in the cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 15, 2008 | Maytag PDB3600A Built-in Dishwasher
The dispenser flap doesn't open
you should check first that power is going to the dispensor at the appropiate part of the cycle. to get at the dispensor, split the door - its screwed together by screws round the periphery. dispensor is just held in by usually 6 obvious screws
Feb 27, 2007 | AEG 23 in. Favorit 44070Vi Built-in...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
83 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Bade
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
