Question about Pelco DF8CB Pg 1V21A Domepak Pendant Color 2.812mm Ai
White screen My camera was working fine but now it has a white out. The piture is almost all white, there are hardly any other colors. I can't even make out what the camera is look at. Yes, I tried to adjust contrast, brightness and saturation to no avail. Please help.
    Scholar:
  • 64 Answers
This could be a termination problem. What type of cable are you using (coax, utp, fiber, wirless) and if its coax is it an all copper center conductor with 95% copper braided shield 75 ohms? Then are you using crimp on/compression or twist on bnc's? this will make a huge difference if its utp is it passive or active....another thing to check would be the device the video is going into (if there are loops we need to check all devices) remember you never want to loop through more then 4 devices....and the end device (dvr, mux, matrix switch,ect) need to be set to terminate or 75 ohms all others set to high z or un terminated... The best check is to take a meter and go to the cameras location and check back to the head end if you are getting a good termination (depending on the distance you see see some ware between 80-95 ohms)..good luck and if you have any questions please let me know
Posted on Oct 22, 2009
  • 3 Answers
Your camera is defetive, ask to the technical person who can check this
Posted on Apr 22, 2008
SOURCE:
Why does my camera have now have a white screen and I can hardly see the pictures..what's wrong with it?
I have a Konica Minolta camera Dimage Z3 that was given to me so I dont have the manual I have the box and cords to it .The promblem is the screen is white it won't let you take pitures you can hear it taking the pics and it will flash but you can't see anything but a white screen. Does anyone know about this type of camera? Thanks so much!
Sep 24, 2010 | HP Photosmart R927 Digital Camera
WHITE SCREEN
The live-view sensor could be defective or broken.
Also, the camera has a viewfinder.
Apr 10, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Blank white screen
It should take pictures fine. Sqeeze the camera hard at the bottom while watching the screen.
Mar 22, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Displays all white in all modes. Kodak V570. Turn the power on and all I can see is white. I have tried a different battery an no battery, just power cord. I know the camera good enough I can go into the...
displays all white because all the color screen have RGB mode if any of mode's are not work correctlly it's mean's color chip was fail and not working. u have to repair ur camera and change ur display screen.
Mar 01, 2009 | Kodak EasyShare V570 Digital Camera
Display
Maybe it's because the camera is overheated, let it cool off. Or maybe it's because the monitor is broken. If so, then replace it.
Mar 16, 2008 | Casio Exilim EX-S500 Digital Camera
My samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
Nov 09, 2007 | Samsung Digimax A503 Digital Camera
White screen with ghost images
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-z500 overexpourse
Jul 12, 2007 | Casio Exilim EX-Z500 Digital Camera
White Screen
Did you find a solution for this? I'm trying to find which LCD would work on this same camera.
Jul 26, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Accurate color
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Pelco DF8CB Pg 1V21A Domepak Pendant Color 2.812mm Ai Logo
263 people viewed this question
Top Pelco Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Pelco Home Security Expert? Answer questions, earn points and help others
