Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Diswasher will not fill clock stays at 130 an
My SGS45E08GB will not fill clock stays at 130 on normal programme and if I change to quick wash the clock stays on setting and will not go down., No water appears to be put in.
  • 183 Answers
This is either a fill fault or a heater fault, for fill fault check side fill chamber is not blocked with fat, for heater check heater, if heater does not activate then the fault is on the PCB programmer, this model often suffers from faulty soldered connections on the pcd, remoce and inspect if required resolder joint. Regards Advisor
Posted on Aug 31, 2007
Hotpoint WMF760 fills with water but doesn't move through programme
Bad motor/ DC power inverter control assembly. My suggestion is don't buy electronically controlled washing machines. They're designed to stop working and for corporate to sell you parts and service again and again and again, until you go buy a rebuilt second hand fully electro-mechanical good ole reliable mechanical top load washing machine.
Feb 07, 2014 | Washing Machines
Need to set time on 1500e lathem
Hello
To enter the programme setting mode, you should plug the AC adapter to AC outlet and remove the cover. Thereafter press 'Select' button once. The the clock goes into the programme mode showing "UP Arrow" on the display positioned at "Time"
Function of three control buttons.
'SELECT": You can select the desired programme setting modes by pressing "Select" buton. Selected programme setting mode is indicated by the "upward arrow" mark on the display.
"CHANGE": When you press "Change" button, you can increment the set value.
"SET": You can set the value selected on the display by pressing the "Set" button. Thereafter you press this 'Set" button again, you can return the clock to normal operation mode. OK.
Dec 14, 2011 | Audio Players & Recorders
Washing machine will not wash or sping
Sounds like motor not running is this due to belt off/ or motor brushes worn or actual motor burned out ? Try the abc to find out. good luck.
Feb 22, 2010 | Washing Machines
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Which programme saves the most energy?
yes a quick wash is for coloured clothes that have been worn once or twice and dont have bad stains on them.This quick wash will take between 30 and 50 mins to do a wash and is the best programme for the clothing that I have discribed ie: worn 1or2 times and no stains will save you on electric and water peter
Jun 09, 2008 | Zanussi Washing Machines
try holding in the start button for 10 sec to see if it resets,or the board could be faulty part no 8801201
Apr 02, 2008 | Dishwashers
Not working
Most likely you have a control panel failure.
Jul 11, 2017 | AEG Lavamat 74640 Front Load Washer
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
566 people viewed this question
Top Bosch Dishwashers Experts
jimorris77
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
