Question about Konica Minolta DiMAGE X50 Digital Camera
White lcd lcd is bright white cant c image . you can only see the menu when you cover the lens with hand can you please helpme thankyou .
    Genius:
  • 2,985 Answers
The camera need to be returned to repair or replacement. To the seller if less than a year or back to Konica if more
Posted on Sep 02, 2007
6ya staff
SOURCE:
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
If i click for photo in day its too brightness because of that i we cant see images properlly please ressolve my problem !!
Turn off your flash light manually and avoid to capture with strong light in front of your lens (sun or lamp)
When you take picture outdoors with much light, try to shade your lens with something, use umbrella or even your own hand shadow to make a shade.
If useful, RATE please !
Jan 18, 2011 | Canon Powershot SX110 IS Digital Camera...
When I turn the camera on the screen shows a white light. No image
  1. Verify that the lens cap is not covering the camera lens.
  2. If operating the camera with a battery, ensure the battery is fully charged.
  3. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  4. Verify that the LCD screen is turned on.
  5. Adjust the LCD brightness control.
  6. Change the shutter speed or aperture settings.
  7. If the issue is not resolved, try resetting the camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 01, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When taking pictures outside bright white photos
i am an train picture guy but neverthe less u cant take anything for granted put cam on "P" and see whad happens and check your manual
Aug 24, 2009 | Olympus FE-220 Digital Camera
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Samsung digimax i5
menu tab.
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Pictures too bright
cover the lens with your hand - if the pix is still bright ? the ccd may be failing ( your dock / computer connection will help in seeing this low light level test ) and if so , parts availability will be your next test ;
May 10, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Konica Minolta DiMAGE X50 Digital Camera Logo
70 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
