Question about Indesit W 123 Front Load Washer
Power supply i want to send my washing washing machine to the philippines but the power supply there is 50-60 htz 220 volts. my indesit front load washing machine is 50 htz 220 volts. According to some people the machine will over heat. Is this true?
    Problem Solver:
  • 12 Answers
The problems with operating a 50 hz unit on a 60 hz power source or vice verse will cause many problems. Some functions my not work at all or maybe they will in a degraded mode. It would not take too long for the thing to blow up though...not literally, but turn itself into a large paper weight. If you want to get them a machine you should order it online or through the international leg of the company who makes it.
Posted on May 19, 2012
    Novelist:
    Champion:
  • 244 Answers
No it should not but if it does yuo should be able to replace the mains filter to a higher power filter
Posted on Aug 19, 2007
No power indesit iwe8123
Most likely control board is defective If all machine is checked for power
Dec 09, 2013 | Indesit W 123 Front Load Washer
Can i plug my hp laserjet pro cm11415fnw to 220-240v,
Some printers have a setting for swithching volts where the power cable plugs into the printer but if it doesnt it will make a big bang and that will be the end of it.
Oct 09, 2012 | HewlettPackard HP LaserJet Pro CM1415fnw...
F-08 code
Indesit 'f08' decodes as ' heater relay stuck' and the advice is 'check PS (power supply)connections for the heater, wiring and module'. Unfortunately this means an engineer call-out ;-0(
Sorry.
Good luck,
John C
Mar 25, 2011 | Indesit W 123 Front Load Washer
Washing machine w/ 110v plug in to 220v
DON'T!
Never plug a 110 volt anything into a 220 volt supply and never plug a 220 volt anything into a 110 volt supply. They are just not designed to do so. Their electronic's power supply and their motors are specifically for the specific voltages. Changing the plug at the end does absolutely nothing.
I just hope I have got to you in time!!!
John C
Feb 19, 2011 | LG Washing Machines
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Indesit
If the water does not get hot, I assume the machine does not complete its programme? Since you have changed the stat, AND checked the element I think the timer may be faulty.
OR has a wire burned off in the heater circuit somewhere? You can test for a 240 volt supply at the two ends of the heat element with a meter, or even a 240 volt bulb.
!!BE CAREFUL!!  !!OF 240 VOLTS !!
Oct 31, 2007 | Indesit W 123 Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Indesit wg 1285w
Replacing the capacitor might solve your problem. Good luck!
Aug 30, 2007 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
110 people viewed this question
Top Indesit Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
