Question about Canon SmartBase MP730 All-In-One InkJet Printer
Blank printout My Canon MP730 printer produced blank printouts for both printing and copying. The machine worked fine before. I've replaced new ink tanks (black and colors) and also tried the maintenance functions to cleaning nozzle heads, but no success. The scanning funtion is OK. Please let me know what else can I do. Thank you in advance.
  • 1 more comment
  • bakkies Nov 26, 2007
    my machine is doing exactly the same
  • Lyn c May 19, 2008
    same problem, came on slowly last week, with some blank pages and some chunks of print missing off some pages. I tried all maitenance and cleaning functions and now there is no printing at all. Changed black cartidge and still no print, either from a copy or a file.
  • florynluka Aug 08, 2008
    My Canon MP730 printer produced 3 blank printouts for both printing and copying.
  • 57 Answers
Try replacing the print head
Posted on Nov 27, 2007
SOURCE:
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
HI guys i have a HP Laserjet M1522nf when i send a print command all the printouts comes out as blank & copy also same blank. please help
You haven't said when was the last time your printer was used.
Ink printers must be used on a regular basis or the ink in the jets dries and the jets plug up.
Jun 20, 2011 | Office Equipment & Supplies
Recently bought a kodak 3250, and had to renew the ink cartridges. i did this twice and still cannot get printer to print any documents. as far as printing pictures is concerned the printout seems to come...
itcould be the coagulation of ink in between the cartridge better dip it in mildhot water for some times and replace it wiping the water . it would do thetrick and solve your problem . it has been practically tested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA
May 16, 2011 | Office Equipment & Supplies
I have a Canon FC244 copier. The paper jammed and I have found a long plate with 2 springs attached loose inside. I cannot see where this should be fixed.
Hi Canon copiers are among the most common photocopying machines available on the market. They are known for their affordability and delivery of quality photocopies of printed pages, and because of this, they have been used in various business and office establishments. Like most copiers, Canon copiers also have their own setbacks and issues, but these can be fixed easily once they are properly diagnosed.
    Issues.Among the most prominent issues with Canon copiers is when the machine produces either full black or white copies. Most users tend to think that the problem lies with an empty ink or toner. If that were the case, however, then they would still receive copies, but the prints would either have unnecessary lines or blurry images. When the copier produces plain white or all black printouts, the problem has to do with internal parts of the copier. Causes.The causes of the production of black or white printouts can be traced to one of two roots: broken corona wires or faulty circuit boards. If the copier has an erratic circuit board, it not only produces all-black copies, it also has a misplaced light/dark slider that has to be manually adjusted in order to produce quality prints. Diagnostics.You can troubleshoot the problems concerning Canon copiers by doing a quick check to see where the problem lies. If you are experiencing intermittent black printouts, see if the bias lamps turn on during printing. These consist of small lamps at the bottom part of the copier drum, where the transfer corona is. The lamps should be not be lit whenever continuous black copies are produced. Faulty circuit boards, meanwhile, can be diagnosed when you have to slam the top-down cover of the machine in order to produce quality, and not blank prints.
Aug 08, 2010 | Canon FC-204S Black and White Copier
MULTIPASS MP730
I just replaced my blk ink cartridge also, nothing prints
Jul 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon SmartBase MP730 All-In-One InkJet Printer Logo
109 people viewed this question
Clive
Clive
old marine
old marine
Ekse
