Question about Dell Inspiron 6400 Notebook
Turns back on
I turn my 6400 off and a min or so it turns back on. Why is this? it has never done this before.
  • 63 Answers
I have seen the power switch itself on some pc's stick when turning them off, or be depressed when shuting them down and signal the pc to turn backon. Check your power switch and make sure its functioning correctly.
Posted on Aug 20, 2007
    Problem Solver:
  • 5 Answers
The above solutions should help. If not,there could be a short in the power assembly. Unfortunately anything associated with power in laptops need a motherboard replacement.
Posted on Aug 19, 2007
  • 3 Answers
First, it would help to know a little about your system. Are you running XP? The major cause of reboot instead of shutdown is Roxio software. If you have it installed, you might note that the light on your CD/DVD drive stays green throughout the process. Alternatively, you may have "wake on LAN" turned on -- but this is unlikely unless you've been fiddling with BIOS settings. If it's Roxio causing the problem, you can find a patch here: http://www.roxio.com/en/support/ecdc/
How do I turn off the bells in a Simplex 6400 clock system
Turn all six switches all the way down. Flip them to the middle position when you want them back on.
Jun 04, 2014 | Simplex 6400
Its dell latitutde 6400 workrd last nite but cant get the screen
Debby, here is what you do; remove the battery. Next unplug the charger from the laptop. (Please make sure it is turned OFF FIRST)
Next, hold down the POWER BUTTON ON THE DELL LAPTOP for at least 30 seconds NON-STOP!!! After 30 seconds, let go of the button. Now, insert the charger ONLY and NOT the battery. If the Dell Logo comes on, problem SOLVED!!!! If not, repeat again.
Feb 27, 2014 | Dell Latitude E6400/ 6400 ATG Laptops /...
The load starts out with 1 hr 3 min on the timer, but during the process the timer may go from 35 min to 40 min, then when it gets down to 29 min it goes back to 34 min and so on and by the time its done...
not sure but sounds like a mother board is playing up, try turning it off at the wall over night just to see if it will reset itself.
if not you will need to keep asking.
Mar 25, 2011 | Washing Machines
Using Dell laptop Vostro 1500, but battery cannot communicate with the system
There might be a possibility that the battery is not making good contact with the laptop's charging circuitry. To eliminate this possibility as a root cause of the battery not charging, turn off and unplug the laptop, take the battery off the laptop, and using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self. When done, put the battery back into the laptop, plug it, and turn it on.
Oct 24, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 i had to reformat and reload all software now when i close my lid and reopen it the screen is black and won't come back on i have to turn off and start up again. all power setting set to...
Machine is going into standby. When you open the lid, press the power button for about two seconds. the machine should come back to full operation and after logging in, you should be back exactly where you left off. I have similar model I am using now to answer your query and I have just done this. No problem. Good Luck, Ian.
Jan 13, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 Vista : the wireless card turns off
is ur WIFI connected thru USB ?
then ur USB is losing power...
check if ur USB setting...
go to Device Manager/USB Serial Bus/USB root hub...
go to each ports one by one....right click on each check properties...check Power Mgt tab....
remove the Tick in the box that says "Allow computer to save power'....
close Device Manager/ Shutdown and restart....
Dec 25, 2009 | Dell Inspiron 6400 Notebook
Ga n650sli ds4l and intel core2 quad blackout when i restart
You need to reset your computer bios back from its original settings. While turning on your computer keep pressing the del key on your keyboard until you get to the BIOS utility screen. Select the BIOS default option and then save settings and exit.
Dec 18, 2009 | Gigabyte GA-N650SLI-DS4L Core 2 Quad...
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
What should i do if my laptops battery indicates to be full when charging but 3 mins after unplugging the adapter it shows 7%.. and then asks me to turn the computer off..!! my laptop is Dell inspiron 6400
depending on how old the system is and how hard it was used on battery the battery may be old and dying and may need to be replaced, from my experince ive seen laptop batterys only last about a year at best
Sep 25, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
51 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
