Home | Hotpoint | 24 in. HDA2000Z Built-in Dishwasher | My Hotpoint dis...
Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Problem for Hotpoint 24 in. HDA2000Z Built-in Dishwasher
My Hotpoint dishwasher won't fill with water. I
By olijoe on Mar 22, 2009
My Hotpoint dishwasher won't fill with water. I have not used it for quite a while and last time I've used it (about a year or two ago) it worked fine.
Comments:
Mar 22, 2009
- Thank you! It is not stuck.
Same Problem
Apr 15, 2009
-   fills slighty then stops. checked bobber thing, doesnt seem stuck. still no results. also removed water drain cover, dosent seem clogged. also checked center water supply tower, seems like it moves freely.-   stmelgrad
Apr 03, 2009
-   I have just replaced the heater element in my dishwasher after it failed, when using for the first time a pipe had come off and caused a leak. This has now been secured but the fault errors Eco and prewash are lit and the dishwasher will not fill. I have checked the filter and pump they are both clear and is not any water in the bottom of the dishwasher. Any advice please?-   Guest
Solution #1
posted on Mar 22, 2009
Somewhat Helpful)
scottowa
Rank: Guru
Rating: 88%, 47 votes
abviosely check that there is water going into it but also check the float switch. There should be a bobber type of thing that goes up and down when the water fills in there. Move that up and down to see if it's stuck. You should here a click of a switch when doing that. If that doesn't do it let me know.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint 24 in. HDA2000Z
Questions and Unsolved Problems for Hotpoint 24 in. HDA2000Z
Do you recommend Hotpoint 24 in. HDA2000Z Built-in Dishwasher?
Answer
Answer
wash cycles not working, load machine, select wash cycle, it then runs but does not clean
Answer
will not wash- not sure if it is the same model, but i turn it on to wash, and it doesnt start a... (More)
Answer
when i turn the dishwasher on the water comes in and it sounds like it is washing but when i open... (More)
Answer
My hotpoint dishwasher leaks every time it starts to drain the water.
Answer
dishwasher starts filling with water, but starts emptying a few seconds later
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA2000Z...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
