Question about Nokia E61 Smartphone
Keys not working
Hello.. some of the keys on my nokia e61 keypad, when pressed, are not registering...e.g. when someone is calling me and I press the green (YES) key, the call is not getting picked up. Similarly, the "A" key is not working when pressed. Possible cause is sweat damage from face when speaking into the phone in hot conditions. Please propose solutions.
  • sbuddha Aug 20, 2007
    fixed (for now)
    turned off the phone, removed battery, and placed in front of a table fan with air-flow directly on the face of the phone for 2-3 hours. everything works now.
  • fergie727 Dec 21, 2007
    e,w,s and x keys not working have tried cleaning the keypad but still not working
    Problem Solver:
  • 6 Answers
I had the same problem once. I forgot my handy e61 was at the back pocket of my pants while i drove home from work. the keys would work, some of the keys got so pressed that they were stuck, it did took me time to unstock these keys by opening my phone. Just be carefull on opening the phone. pls.
Posted on Jun 02, 2009
  • 3 Answers
There's a foreign object between the keypad and the sensor pad ... dust or lint or a hair or a scrap of paper ...
This is an easily repaired problem that someone with very basic skills and tools can tackle. The steps are:
- Remove battery cover
- Remove battery
- Start disassembly by removing top rear shell (the bit with the lens cover) by gently prising with a small screw driver. There are five catches - one middle left, one middle right right, one center bottom, two at the top +/- 1/2" from the edges. Gently remove the in the same direction as you would the battery.
- Remove front shell by undoing 4 screws now visible on the rear of the phone, one at each corner. Itis a funny torque screw, but I used a small flat and it worked OK
- Gently dust and clean the entire phone
- While you're about it, make sure the screen connector is properly engagde. Turn the phone face up. Right at the top and about 1" from the left there is a red screen connector (you'll see the copper of the screen's strip cable terminating there). Gently press down on this connector to reconnect.
- Reverse the steps for re-assembly
If you do not feel up to it, take the phone to an agent or repair shop with these instructions. It is a 5 minute job and they should charge accordingly!
Francois
Posted on Nov 12, 2008
    Sergeant:
  • 452 Answers
Open ur phoen as much as possible and put in su lite for more than 2-3 hrs. and if doen't work then go to service centrre.
Posted on Oct 18, 2007
SOURCE:
How do i un freeze my nokia twist
  1. Make sure that the keys are actually locked. If you attempt to unlock a keypad that is not locked, nothing will happen. Look on the phone's screen for the key icon that indicates the keypad is locked. If you try to press any of the keys and the word "Unlock" appears on the screen, your keypad is definitely locked. If you do not see the indicator but are unable to use the keypad of your Nokia 6085, your battery could be dead, so try recharging it and then see if the keypad works.
  2. Enter the unlock sequence. If the key indicator appears on your screen, you need to enter a simple sequence of keys to get the keypad working again. For the Nokia 6085, select Unlock and then quickly press the * key. If you wait more than 1.5 seconds to press the * key after selecting Unlock, it will not unfreeze the keys so make sure you enter the sequence very quickly.
  3. Turn off the automatic keyguard. If you are tired of having to unfreeze the keys every time you want to make a call, you can program the Nokia 6085 to always remain unlocked. In the menu, go to Settings, then select Phone, then select Automatic Keyguard and choose Off.
Mar 01, 2012 | Nokia Cell Phones
When I press CALL key it dials 4 and when I delete RED(call cancel key) it dails 6!! And when I call someone or someone call me i hears his voice but he don,t!!
There are two problems in your phone, First one is your keypad and the second one is Microphone.So for keypad you need to change the keypad IC (filter) and fir mic you have to change the Mic/Mic IC.Therefore my comment is to contact mobile repairing shop.Good luck
Aug 30, 2011 | Nokia 3110 Cellular Phone
How do you unlock the key pad on a Nokia phone
Hello
To unlock your keypad press the top left key on your keypad and the star (*) key on your keypad, this unlocks the keypad...
Apr 11, 2011 | Nokia 6085 Cellular Phone
My N73 shows a message like this"phone memory is full" but i have deleted ALL of my datas in phone memory, i really dont know what else should i do!!!
Hello
You might have to format your phone memory.
Unlock your Nokia N73's keypad by pressing the left soft key found just above the green call button and then pressing the "*" or asterisk key.
Press a series of five keys on your keypad following the sequence "*7370#" without quotes. Assume that you are dialing this as a number. The N73 should show a confirmation message right after you press the "#" key.
Read the Warnings section before proceeding and choose the "Yes" option from the confirmation message to tell the Nokia N73 to format the phone memory.
Oct 04, 2010 | Nokia N73 Cellular Phone
How to reset nokia E61 mobile
1)Try this first *#7370# and enter Default code 12345 or 00000 2)If the Above doesn't work Try *#7780# and enter code 12345 or 00000 3)If the above 2 doesn't work, then finally try this, Switch of the mobile and press * + 3 + Call button + switch on the mobile and hold the 3 keys till the nokia welcome screen displays. Hope this Helps.
Jun 20, 2010 | Nokia E61
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 | Cell Phones
The keypad on my nokia 5310 will not lock even though keypad lock is switched on
1.5 seconds. If Security keyguard is set to on, enter
the security code if requested.
call key. When you end or reject the call, the keypad
automatically locks
Aug 30, 2009 | Nokia 5310 Cellular Phone
NO DETECTION OF KEYPAD ON THE NOKIA CELL PHONE
take of the battery while the phone is still is alive
if it doesnt work try formatting(aftersaving ur files in the computer)
press the (greenbutton + * + 3 ) and while pressing these switches , switchon the mobile
i know it sounds funnyand its a long process(40 sec) but shld help if its a software problem
PS;the above key combinations should be done only when the phone is in the switched off stage
the key combinations should be kept on hold while pressing the power button for abt 10 sec
if none of these work better take it the dealer
May 18, 2009 | Nokia 5320 XpressMusic Cellular Phone
Keypad not working when phone in use
There is a button on the left side of the phone which pops up the keypad.( dauden )
Mine registers just fine. (born2shop)
Dec 23, 2007 | LG Prada KE850 Cellular Phone
Nokia E61 Smartphone Logo
170 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
