Question about Gigabyte GA-8I845GV-C (GBSA4LB) Motherboard
AGP card support
Does Gigabyte GA-8I845GV motherboard support graphics card..and whether it comes in PCI slot or AGP slot?
    President:
  • 1,114 Answers
The board has no AGP slot & only 3 PCI no PCI-E slots. Has on board graphics. You can download the manual from the link below: http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ClassValue=Motherboard&ProductID=1744&ProductName=GA-8I845GV-C Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 19, 2007
    Brigadier General:
  • 6,966 Answers
Hi, Unfortunately no AGP slot nor PCI-E. The Gigabyte GA-8I845GV motherboard has only 3 Expansion Slots and all of the are PCI (33MHz & PCI 2.2 compliantt). From their website, here's an image of the motherboard http://www.giga-byte.com.tw/FileList/Image/motherboard_productimage_ga-8i845gv_big.jpg It has a built-in Intel® Extreme Graphics Engine (845GV chipset) for video with max of 128 mb shared memory. Should you wish to install an add-on 3rd party PCI video card, Inno3D FX5500 256ddr PCI slot tv-dvi are still available (at least in my location) for an equivalent of about 3.5K INR (80USD+). Hope this gives you an idea. Good luck and kind regards.
SOURCE:
VGA Support?
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2358#sp
Your mainboard supports 1 x AGP 8x slot ( the green slot )
The new PCI-e express does not fit the socket.
When you add a bigger graphic card, you will probably need a bigger power supply.
I recommed a 500 watt or bigger.
Most external graphic cards uses 150 to 250 watts, depending of the size of the card.
I also recommed ATI/AMD graphic cards.
Such graphic card, can be bought online, or in a computer shop.
Good luck
Feb 07, 2013 | Gigabyte GA-8I865GME-775-RH Motherboard
What kind of video card works in a ga7n400 pro 2
Hello the mainboard supports AGP slot video card.
Pci-e is the latest but it does not fit your mainboard
You can read more here:
http://www.gigabyte.com/products/product-page.aspx?pid=1678#sp
1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
You can still buy an agp video card but it can be hard to find.
Good luck.
Sep 09, 2012 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
I have a Gigabyte GA-K8VM800M Motherboard with 2gb ram. I want to disable the onboard graphics card and add another VGA card. Which card should I go for?? Will adding VGA card, show physical memory as 2gb...
Hello you can download the manual, and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
You can add a graphic card 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
And Max capacity: Up to 2GB DDR400 RAM by 2 DIMM slots.
ATI/AMD makes very good graphic cards.
Adding a graphic card on the mainboard will not slow the physical memory. It has it`s own ram.
Good luck
Jun 18, 2012 | Gigabyte GA-K8VM800M Motherboard
I try to find a HD videocard compatible with my motherboard Gigabyte GA-K8NF-9 Rev1.1
Hi, you can see the specifications here:
http://www.gigabyte.com/products/product-page.aspx?pid=1860#sp
  1. Its a PCI-Express X 16 slot, supports PCI-Express interface Graphics card
Aug 27, 2011 | Gigabyte GA-K8NF-9 (890552602964)...
Hi, i want vga driver for GA-81845GV mother board
Hi, you can find the driver here:
http://www.gigabyte.com/support-downloads/support-downloads.aspx
Try searcing for the right mainboard number.
The number is printed in on the mainboard near the pci slots.
If your mainboard has an external card you have to search for that.
Try even to run windows update.
Hope this was helpfull.
Aug 14, 2011 | Gigabyte GA-P35-DS3L Motherboard
I want a graphics card for 81845GVM-RZ motherboard......please help me
Your motherboard is old one.
For adding the new graphics card you need to have the PCI Express x16 slot in motherboard
Your motherboard is not having this slot.
Buy a new motherboard.
Thanks for using FixYa.
May 15, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
I want to add a grapic card to my motherboard..
you will need an AGP type graphics card for this motherboard, not a PCI-E....hope this helps
Feb 08, 2010 | Gigabyte GA-7VKMP Motherboard
I believe that my agp slot went bad so i bought a new video card that uses a pci slot instead how do i access bios to configure this when recieving this error code at post 1 long 2 short gigabyte...
Hey,
1 long 2 short is video card failure.
if you had a pci slot card inserted in the agp slot and you powered on, the motherboard may be damaged.
Feb 18, 2009 | Gigabyte Computers & Internet
ATI Radeon Saphire 9600Pro AGP Graphics Card
It appears that the mobo is AGP 8x, and this video card also appears to be AGP 8x - so you should be able to use it just fine.
Jan 26, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Gigabyte GA-8I845GV-C (GBSA4LB) Motherboard Logo
224 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
