Question about Toshiba 27A34 27" TV
Setting the channels
Hi I bought this Panasonic colour T.V. second hand but their wasn't a Manuel to show how to set the channels on the T.V.. The model # is TZ-20L3Z. I know that it is a fairly old T.V. but it works very well. Can you give me a little guidance on how to set the channels up. Cheers from N.Z. Chet
  • 1 more comment
  • kwie1310 Aug 20, 2007
    Sorry. The # is TC20L3Z
  • kwie1310 Aug 21, 2007
    Thanks for all the help. Sometimes it takes a little while for it to sink in
  • Anonymous Mar 20, 2014
    set top box displays all channels apart for channels from channel 9
    President:
  • 1,114 Answers
You can download the manual from the link below: http://safemanuals.com/download_94794.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 19, 2007
  • 2 more comments
  • Greg Cann
    Greg Cann Aug 20, 2007
    I gave you a link to the manual in the category you selected i.e. 27A34. The model number you quoted TZ-20L3Z does not exist! Please check & give the correct number if you want the correct manual!!
  • Greg Cann
    http://support.panasonic.co.nz/docstore/...
  • Greg Cann
    Please try this link again:
    This is the manual for the TV!
    Please describe any problem you have accessing this link.
  • Greg Cann
    Greg Cann Aug 21, 2007
    We got there in the end!
    Although I am now in Spain I was born in NZ, my dad was on HMNZS Achilles! NZ involvement in the Pacific war never got the recognition it deserved, sorry rant mode OFF.
    Thanks for the good feedback, it makes it all worthwhile!
    Best regards,
    Informatica.
Problems setting up new Panasonic LED-LCD TV
the TV may require an special antenna for the unit or the unit is set for cable operation
TV units have buttons on the side or near the side where initial settings can be obtained without the remote
remove the antenna cable and see if that indicates an aerial problem If you go to some shops they have a geek on hand that can show you how to fix on a shop demo unit and what you will need
Jun 13, 2015 | Panasonic Televison & Video
I've bought a Panasonic TX- L42B8B smart tv and it wont let me watch youtube or other things smart tvs do any reason why?
is this from new or secondhand. as new its should have setting in ipaddress tv setting. second hand then you need the system rest, back to factory setting. make sure the ether cable is out when doing this. after doing this and tv is up and running a gain go on to the panasonic apps and look for updates. ( ether cable pluged in)
Sep 15, 2013 | Televison & Video
When i put a new bulb in my projector panasonic ptae1000 its shows green how do i fix this
A new bulb may just be showing up a problem that wasn't apparent with the lower brightness coming from an old bulb.
Try putting the old bulb back in and look very carefully and see if the problem is still there.
If the green is uniform over the whole screen then it may be fixed by setting a colour level change in the menu.
If it varies over the screen then it is probably a polarizer affected by age and heating.
Jul 14, 2011 | Panasonic PT-AE1000U LCD Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Preset channels on Panasonic car radio out of tune
this is simple enough to do, just find the channel you want to save, then press and hold a number u want to save it to!
i.e No. 1 - 96.9Fm
hope this helps
Feb 15, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
Panasonic TV Instruction Manual
Is there anything mentioned about cable accessible via the remote ... assuming you have one that works for the unit?
Apr 23, 2017 | Panasonic Home Theater System System
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Guide to setting the channels
Hi Chet, At most that I can give you is a generic procedure but should work also in your unit other than the names/terms would probably be a tad different. Using your remote, press menu, select setup. You may have to select whether you are using cable or aerial. Aerial antenna could be name Air or Std. Normally there would be a search function or add channels or memory + or something like that. Am not sure but you may have a save butoon also but not always. Hope this gives you some idea. Pls post back how things are or if you need further information. Good luck and kind regards.
Toshiba 27A34 27" TV Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
