Question about Philips GoGear HDD1850 MP3 Player
Wont turn off
My daughter can't acess player, appears to be locked up. Can't turn on or off blue light stays on near the slide control. Is there anything I can do.
Try holding the On/Off Switch in the Off position. At the same time press and hold the Volume Up on the other side. After a few seconds it should switch off and work as normal.
Posted on Jan 02, 2008
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a sansa mp3 tht has locked up on me. a picture of a lock appears as if there is some way to lock the device.
There's a sliding switch near the "record" button. Slide it to cover the orange in order to unlock the unit. Slide it to reveal the orange to lock the unit.
May 25, 2010 | SanDisk Sansa MP3 Player
Lock appears on player
There's a slide switch on top of the unit, near the headphone jack. Slide it away from the jack to unlock the Sansa.
Apr 30, 2010 | SanDisk Sansa e260 MP3 Player
MP3 player GHT D2000 appears locked
hi shreejit here try to reformat the mp3 player so the code will be unlocked and u can use your mp3 player in a normal state
May 31, 2009 | Audio Players & Recorders
W760I WONT SLIDE UP
hi, carfully unscrew it, looks like the spring in the mechanism is stuck, the phone shop wont charge you much if the is no damage.
Mar 31, 2009 | Sony Ericsson W760i Cellular Phone
Samsung mp3 touchscreen player wont start
Turn It on the side, you will see the power button and a slide thing. Push the slide thing DOWN if it is up and then turn it on.
Dec 26, 2008 | Samsung P2 MP3 & Video Player
Sansa 2.0 mp3
Key lock means the HOLD switch is on.
Slide it the other way.
Best of Luck.
Nov 27, 2007 | SanDisk Sansa c150 MP3 Player
Vm9312
That is the code for the older jensen's The parking brake bypass procedure is as follows: 1: Go into AM/FM mode 2: Hit "setup" on the remote control 3: Enter 543210 on the remote, listening for the beep for each number entered 4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen. 5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
May 25, 2007 | Jensen VM9510 Car DVD Player
Philips GoGear HDD1850 MP3 Player Logo
116 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
