Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Error in windows xp
Their is a problem in my system a popup window is appear, Nooh error and message is written on this open task manager now task manager,folder lock and registry are not open please give its solution i use winxp sp2
Log on to windows XP safe mode and look for c:windows\web\sys.exe . Pls rename the sys.exe to other name. It will solve ur problem. Note : the sys.exe is system protect file. you have to go to folder option to enable to view system protect files . soon hoe (Malaysia)
Posted on Sep 23, 2007
  • 63 Answers
How long has it been since this started? Do you do maintenance on a regular basis? Meaning: Virus scans, spyware/adware/malware scan and delete? Do you do regular "system restore" points? If you do, or can find a "check point" somewhere before this issue stared happening, you can restore to that point and see if the problem cleared. Good luck and let me know if any of this helps.
Posted on Aug 20, 2007
I would suggest using Spybot Search & Destroy and see if you have any spyware software loaded. Also scan for viruses and use adware to ensure that you are not infected with anything. This should help!
Posted on Aug 19, 2007
My computer ask for genuine microsoft software
Hi, Try Referring this link. http://windows-xp-genuine-crack.blogspot.com/
or This is a torrent link and so you download bit torrent software and install it from www.bittorrent.com
Download the software in the below link and install it to make your windows xp genuine if your os is not original 1)Go to the below link http://thepiratebay.org/torrent/3550335/Make_Windows_XP_Genuine_in_5_seconds._No_more_WGA_Cra cks.
2)Click download this torrent which will be written in green colour 3)open the downloaded torrent file and the software to make your xp genuine will be downloaded OR To remove and byepass this message: To remove and to by pass this message there are two options: First Method:
1) Lauch Windows Task Manager by pressing cltr + Alt + Del. 2) End wgatray.exe process in Task Manager. 3) Restart Windows XP in Safe Mode. 4) Delete WgaTray.exe from c:\Windows\System32. 5) Delete WgaTray.exe from c:\Windows\System32\dllcache. 6) Lauch RegEdit. 7) Browse to the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\Notify
8) Delete the folder 'WgaLogon' and all its contents 9) Reboot Windows XP.
Nov 29, 2010 | Microsoft Windows XP Professional for PC
My yahoo messenger cannot be opened. when I clicked open a dialog box appeared and "failed to initialize properly' is written
Uninstall it and do the following . Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reg in out also reboot your system. All other background applications will return to their original configurations.
Sep 30, 2010 | Yahoo Messenger
Windows did not appeared, only mousepointer was appeared. The icons on destop, taskbar and start menu are not appeared. What are the best solutions Tank you!
Press Ctrl + Alt + Delete together and Task manager will be opened. Click on file -> New task . In the box type explorer.exe.a nd click ok. If this doesn't works boot your computer from XP disk and run repair from disk.
May 27, 2010 | Microsoft Windows XP Professional SP2
Thanks Mark
So the error message worn go away? did you try opening up task manager and check what is the operation that is causing the error and try to end the task using task manager...
Nov 02, 2008 | Microsoft Windows XP Professional
Problem with Administrator Settings
try to open the windows in safemode to open windows in safe mode press F8 when your system start
if you can work in safemode try to restore windows to a pervious date
Apr 30, 2008 | Sony VAIO PCG-V505EC Notebook
Windows giving blank window while opening PC
Try pressing F8 before while booting and run Last Known Good Configuration. Also try to boot into safe mode and uninstalled IE 7.
Let me know what happens.
Apr 13, 2008 | Computers & Internet
Hide task manager
hi dear
start menu, run
type regedit
find this....
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
change dword to 000000000
oke
Mar 19, 2008 | Microsoft Windows XP Professional
Windows cannot find scvhost.exe
This is the Internet Virus , to overcome this , you may kindly be taken following steps .
Step 1: Write click on the start button task bar .
Step 2: Select Task manager by left click of you mouse.
Step 3. Under the process option , select line
svchost.exe system Administrator
Step 4. Select End process .
Step 5. Repeat Step 3 & 4 until the end of the bellow message.
svchost.exe System Administrator
Step 6. Close the Windows Task Manager by click X button .
or
Run the Original Quick Heal / AVG antivirus software in your system .
The steps are the solution for your problem.
OK
nilamani
nkjbbsr@yahoo.co.in , nkjbbsr@rediffmail.com
Dec 21, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
132 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
