Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Sony HC-40E Charging Problem
I have a sony dcr hc40E minidv handycam since last 3 years. recently i am facing typical problem. even if the power is off, the red light on camcorder's body for memory stick flashes. with or without the memory in, the charging light doesn't come on and charging doesn't work. battery information also does not get activated. this problem looks like the one posted by aksh on oct, 14 2006. I'd like to try the solution posted by x-tian on aug, 11 2007 but I don't find the "short line to the carbon wire of the function switch" Pl help.
  • Rollswing Sep 27, 2007
    actually,I got in touch with Sony and they will lool free of charge.
    my diagnose is that the camera doesn't detect correctly the status of the battery, moreover the battery is automatically discharged when staying in the camera powered off.
    When I recharge the battery with an external charger everything goes fine
    kr
    jcbar
  • andyaz Nov 21, 2007
    I have a sony dcr hc40E minidv handycam over 3 years old. Can charge battey - even tried firiends with same battery - appear to be in the camera. Looks like the same problem posted by Rollswing on Aug 19, 2007 - even if the power is off, the red light on camcorder's body for memory stick flashes. with or without the memory in, the charging light doesn't come on and charging doesn't work. battery information also does not get activated.
Try loosening some of the screws on the handycam, to allow you to prise open the case slighly, allowing access to the strip coming from the switch. Cut a thin piece of rubber from an eraser, and gently stroke the wire strip with it. It works!
Posted on Sep 03, 2007
WHEN i SWITCH ON THE CAMCORDER IT SAYS SET CLOCK, BUT THE SCREEN DOES NOT MOVE ANS STAYS PUT IN THE YEAR. ITS A DCR-HC 40E
-set the year as first shown using or by touching the up or down arrow in the lcd screen then press ok to switch to month.
-do the same thing with the day( always use the up or down arrow located in the lcd screen to change the numbers then touch ok to confirm.
Jun 05, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
While capturing video from sony DCR-HC 40E via pinnacle 14 HD through IEEE 1394 in wondows 7, the captured video showed too many frame drops.
Sounds like time code breaks.
If you stripe the tape (record in one continuous run with the lens cap on and audio off) this will assist greatly.
Feb 17, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
I've a Sony DCR-HC 30E/HC 40E Handycam. I've lost the CD-Rom software. I've a Windows XP PC. Kindly let me know ASAP how can I installed the CD-ROM to transfer Videos from Handycam to my PC via the...
With the firewire cable, you can use Windows Movie Maker to download videos from practically any digital camera with firewire connection (Sony called i.Link).
Feb 08, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony DCR-HC 40E touch screen not working
hi, you must change the lance flap, its a problem of lance flap so just replace it and its a ruttin problem,
Aug 30, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Moisture problem dcr-hc 40e
Thanks for your assistance , I have sent my camera to Sony Service Centre here in Delhi , India
Regards
Madan
Jan 14, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony DCR HC 40 E driver
I had purchased the laptop with Window Vista Home Premium OS. I am unable to connect my Mini DV Sony DCR HC 40 E through firewire. the laptop doesn't recognise mini DV. Please suggest proper driver & solution
Aug 16, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony DCR-HC40E Tape Holder Mechanism load failure
Your camera needs Mechanism replacement.
Software CD is available on charge basis.
Apr 30, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
Oct 14, 2006 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
300 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
