Question about Symantec PcANYWHERE Host & Remote 11.0 for PC
PCANYWHERE not connct ohter pc
    Problem Solver:
  • 15 Answers
Just put the firewall off and you will be able to connect to the other PC you dont have to shut down the antivirus
Posted on Aug 19, 2007
  • 883 Answers
Try disabling both antivirus and firewalls on both pcs.
SOURCE:
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
Trying to open ports
You will need to setup Ports 5631 and 5632 to forward to the IP of the computer with PC anywhere installed on it. You need to go into the Virtual Server section to setup the port forwarding.
Apr 22, 2009 | Computers & Internet
How to set 5631 tcp and 5632 udp
You need to access the router via a web browser. Standard addresses are 192.168.0.1 or 192.168.1.1.
If neither work, you need to go to start>run> type in "cmd" then OK. Once you get command prompt up, type in ipconfig (Then enter). The Default gateway is the address to your routers configuration page.
Once you get in go to/find virtual servers and and the ports in there. for the ip set it to your computers local ip, you can find it in run>cmd >ipconfig thing i told you earlier. It would be under IP Address
Feb 27, 2009 | Belkin (F5D5231-4) Router
PcAnywhere Host Administrator
Hello , the best way I have to solve that problem, is click on this link , they can checking on you device and see what is bad
Mar 12, 2017 | Norton pcANYWHERE 11.5 Host & Remote...
Can we connct furuno gp31 to pc
Hello!
Yes, the GP31 can connect to a PC.  With the wiring harness, it has an RS-232 port, which allows it to connect to most PCs, laptops, and even most palmtop systems.
Hope this helps you out,
Ken
Sep 19, 2008 | Furuno GP31 GPS Receiver
Found the check box - for Block WAN
I believe your initial problem was for PCAnywhere rgiht? just make sure ports 5631 (Data Port or TCP) and 5632(Status port or UDP) is properly opened/forwarded on your router's config page plus make sure that you instruct the router to forward those ports to the computer that you have PCAnywhere plus I have read some articles that newer versions of PCAnywhere 10.+ 11.+ will not work with older version 5.+
Now if it still doesn't work try setting up DMZ for you host computer(Note: enabling DMZ will open a wide range of ports, well common ports that is).
Jul 02, 2008 | Linksys Wireless-G WRT54G Router
PcAnywhere 12.0 System Builder Edition
PcAnywhere 12.0 is not compatible with Windows Vista. PcAnywhere 12.1 is. You can find it here: http://www.symantec.com/business/products/purchasing.jsp?pcid=2247&pvid=840_1
Whether or not you are entitled to a complimentary update is unclear, although generally speaking users are normally entitled to updates as long as the version remains the same. (So in this case, because the new version is 12.1, you are likely entitled to the update, whereas if the new version was 13.0 you would be more likely out of luck.)
I would recommend using the "Live Chat with online sales" option at the URL I provided to clarify your licensing questions.
Regards,
Javabytes
Nov 05, 2007 | Symantec pcANYWHERE 11.5 Host for PC
CyberXLink CXL-EBR-W router - can't open ports 5631/5632 for pcAnywhere
Hi dave, I'm not familiar with that router at all and I didn't find any doc's online for it so I'm running blind here but... If the router has it make sure "Block WAN Request" is disabled or you won't get anywhere. Also I don't know if the print server has anything to do with your problem. Have you tried mapping those ports directly to the host in the router? TCP PCanywhere port 5631 Inbound 192.168.1.[host IP] port 5631 UDP PCanywhere port 5632 Inbound 192.168.1.[host IP] port 5632 I'm also assuming that you're using a static IP on the host. You don't want to use a dynamic IP. Hope this helps. Let me know how you make out, Duder
Nov 17, 2006 | cyberxlink (CXLEBRW) Wireless Router
Trouble with PCAnywhere locking the port
Ok ensure that nothing has changed.. Check the Firewall setting, at BOTH ends, to ensure that the "Port" is Passed thru.. also check to make sure the address's used by PCanywhere are the same at both ends. Perhaps the port ya been using has become "Blocked" somehow? OR some setting have been changed.. carefully check it all out. GL
Nov 03, 2006 | Adtran Total Access 616 Router
Open Questions:
See all Symantec PcANYWHERE Host & Remote 11.0 for PC Questions
Symantec PcANYWHERE Host & Remote 11.0 for PC Logo
63 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
