Computers & Internet Logo
Anonymous Posted on Jun 08, 2013
Tomtom 2 winlatest exe
I am trying to update my TomTom and I keep getting a can not find WinLastexe How do I find it or reinstall this
Ekse
Level 3:
  • Dell Master 13,435 Answers
  • Posted on Jun 09, 2013
Ekse
Dell Master
Level 3:
Answers
13435
Questions
82
Helped
3984684
Points
38023
Re-install tomtom from the original cd or dvd media.
2answers
I have a tomtom go 720 and the maps have been deleted where can i go to get them back ?
register the device, tomtom home will reinstall the original map that was on the unit when new
You can download TomTom Home at the TomTom website: https://us.support.tomtom.com/app/answers/detail/a_id/6218
Sep 24, 2013 • Tomtom GPS
Tried to attach to computer to update since then all I get when turning it on is a flashing red cross and can not soft reset
Since you have said that your TomTom is only displaying a flashing cross (or "X"), it is because the TomTom application is not installed or can not be found. This usually happenes when you attempt to update your unit and it is interrupted (i.e., not properly disconnected from the computer, the TomTom was underpowered by using a USB port on your monitor/keyboard, or lost power during the update. In fact, it might just be pissy.)
Down to how to fix it: You essentially just need to reinstall the application.
1. Soft reset (I know you have already done this but am providing a link just in case: http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/popup_adp.php?&p_faqid=6965)
2. Connect you’re GPS unit to your computer
3. Press the power button for about 5 seconds and the TomTom Home will start.
NOTE: It is highly recommended that you use TomTom HOME to make a backup. You can find out how to do this here: http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_adp.php?p_faqid=3171&Lid=1
4. Delete application files (so we can do a clean install), to do this:
- in HOME, click "MANAGE MY NAVIGATION DEVICE"
- Select the ITEMS ON DEVICE tab and tick the box by "APPLICATIONS".
- Then click REMOVE ITEMS FROM DEVICE
- A warning will pop-up, click "OK"
- Select the ITEMS ON COMPUTER tab and tick the box by APPLICATIONS
- Then click REMOVE ITEMS FROM COMPUTER
- Another warning will pop-up, click "OK"
5. Reinstall the TomTom Application by clicking UPDATE MY DEVICE
- Then click UPDATE AND INSTALL
- Once done, click DEVICE > DISCONNECT DEVICE
6. Next, we're going to run the TomTom Clear Flash Tool (the downloads include step-by-step directions for clearing the flash)
- for windows: http://www.tomtom.com/updates/clear_flash/clear_flash.exe
- for mac: http://www.tomtom.com/updates/clear_flash/clear_flash.dmg
7. Safely disconnect.
- on windows: click the SAFELY REMOVE HARDWARE ICON (a icon with a green arrow that is hanging out in the system tray and then choose "USB MASS STORAGE DEVICE" from the pop-up
-on a mac: drag the desktop icon of your device to your trash.
8. Your device should start up automatically. If it hasn't within 10-15 seconds, press the on/off button.
You're done!
If by chance this still doesn’t work, you can try formatting the internal memory or memory card of your TomTom. If you need a link or directions, simply send me a message or reply!
Hope this helps!
-TJ
3helpful
TomTom XL stuck on front screen, how do I reset it
You're done!
Hope this helps!
-TJ
Dec 27, 2009 • Tomtom GPS
3helpful
Unable to update Tom Tom in windows vista keep getting error 1060 any solutions?
perform the following:
type the following three lines in to the Command window:
%SystemDrive%
cd "%ProgramFiles%\TomTom HOME 2"
xulrunner\HOMERuntime.exe -app xul\application.ini
To avoid having to type these lines every time you start HOME:
Right-click your desktop and choose New > Text Document - enter the commands provided above and then save the file as RunTTH.bat
copy this file to the TomTom HOME 2 folder in C:\Program Files (you will require Administrator rights to do this)
in the Start menu, right click on the TomTom HOME 2 icon.
select Properties
in Target, change "C:\Program Files\TomTom HOME 2\TomTomHOME.exe" to "C:\Program Files\TomTom HOME 2\RunTTH.bat”
The icon will change and HOME 2 should now run normally on your PC.
Please note that links like "Send to TomTom device" or "Add to TomTom" won't work because they rely on TomTomHOME.exe (which this workaround by-passes).
A full fix for this error will be implemented in a future HOME update.
NOTE: for 64 bit Vista change the second line of code to:
cd "%ProgramFiles(x86)%\TomTom HOME 2"
3helpful
3answers
I cannot get tomtom home .The message Home runtime.exe failed with error 0 appears. Please help
i cannot get tomtom home the message home runtime.exe failed with error 0 appears please help before i have to return and get a different make my tomtom tels me to update but want conect , thanks . sean
2helpful
2answers
TomTom Home will not download from www.tomtom.com
I have down loaded western map from tomtom home for free and all my map of the UK vanished and now there is no map in my tomtom will any one help me out to solve my mysterious problem rasana
1helpful
3answers
Iv got an backup issue with my tomtom one.after backup with microsoft windows xp backup and restor software,i wrongfully formated my tom tom one,now when i restor my backup with windows xp...
I do some work with TomTom - it's possible that if something interrupted or went wrong during the install, the map could have been deleted. TomTom is aware of the problem and is working to fix it - if you are map-less, call support (866 486 6866) and we can work on getting you a new map.
1helpful
2answers
I can't get your website to update my tomtom divce. It tells me to go www.tomtom.com/home and reinstall. But I can not fined the place were it says to, reinstall. I realy enjoy my navigator. Plus I...
reinstall. I realy enjoy my navigator. Plus I move
from Missouri to California, and I update that part.
Please help fix this problem.
posted by lakend
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
