Question about Samsung LN-R409D 40 in. LCD Television
Samsung LTN325W LCD TV Sound Static Problem
We inherited a Samsung LTN325W LCD TV, with only one problem. When you turn it on, it emits a constant static-y sound that only dissipates after an hour. We plugged headphones into the unit, and the static was NOT heard over the headphones. Question - is this an expensive fix? And what exactly would cause this? It's reminiscent of the 'snow' sound you would hear on older tvs. Thanks a bunch!
SOURCE: Samsung LN-T3253H LCD Sound Problems
I finally got mine fixed. All the 3253h have this problem. It took two service trips because Samsung messed up the service bulletin. I had a court date and everything for my local CC, but I finally got the issue resolved. There is a choke around a coil on the power supply board, when the tv is warm that is what is making the noise. The coil/choke was replaced with a new version and the sound is gone. Strange but this is not a component level fix. A new component gives you the same problem. Either way I'm happy now
Posted on Mar 08, 2008
SOURCE: Firmware update caused static on the display
See previous comment
Posted on Nov 19, 2008
  • 1039 Answers
SOURCE: Powers off after several minutes
Check and replace swollen capacitors in power board.
Posted on Apr 25, 2009
  • 257 Answers
SOURCE: Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Posted on Aug 18, 2009
SOURCE: No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
Posted on Dec 01, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Red blinking light/ strange sound
about the only easy possible thing would require taking the set apart and looking where the display panel connects inside the set==a loose or open plug is about the only simple thing.
Sep 01, 2012 | Samsung LN46C750 46 in 3D LCD TV
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Strange buzzing sound
Hi there! If it is an anoying sound I would personally have it checked if still under warranty. It may be a bad coil or transformer in the power supply. Enjoy what you paid for rather than sitting with a fault that might cost you extra later on. Best Wishes and Good Luck, JUS004
Aug 22, 2009 | Televison & Video
Same problem
Do you have to turn the TV off and then on again to get the sound prob to go away? Our sound problem happens 10 to 15 x per day depending on how long the TV is on.
Jul 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Memorex HD LCD TV, 26'', static noise
try retuneing it. i had this problem yesterday and i tuned it again and that fixed it
Apr 07, 2009 | Memorex MLTD2622 26 in. LCD TV
Samsung tv
as far as it turning off on its own I would get a fan on it and see if that make a difference make sure that the fan is able to flow around the tv especially through the back of it, if this stops it from turning off then it is an overheating problem
Mar 22, 2008 | Samsung HCN4226W 42" Rear Projection...
Audio static
Hi: An alignment of the video if and or the audio circuits may be necessary in a repair shop.
How old is this set?
Al
Mar 17, 2008 | Televison & Video
Samsung LN-R409D 40 in. LCD Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
