Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
Anonymous Posted on Jun 08, 2013
Not moving, pulsates slowly - Universal Kreepy Krauly In-Ground Pool Cleaner
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 12, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
696
Points
I had a similar problem with mine starting to move and pulsate well enough but then slowing and stopping altogether. back washing the filter solved it. I guess it wasn't getting enough suction as my pump couldn't power through the filter well enough.
Fix noisy and pulsating brakes
If the brake pedal pulsates while high speed braking, the rotors are warped/out of round. This can also produce noise as it can cause the caliper to move back and forth. You either have poor quality/cheap parts installed or the parts were installed with improper lube on the slide assemblies and there is dirt/rust causing the pins not to move freely or the pad shims are old and rusted causing the pads to stick and overheat the rotors. Have the brakes inspected for the source of the problem
2answers
Why does my 2000 Monte Carlo SS pulsate between 50-60 mph?
check the TPS sensor as it could have a bad spot in it. also the trans maybe going in and out of overdrive at that speed.
Landa pressure washer LT 4035-4000 psi. Why is it losing pressure and continually pulsating?
If the pump is pulsating rapidly most likely valves are leaking or debris under valve keeping one or more from closing. If the pump pulsates slowly, comes up to pressure then low pressure then repeats, problem is pressure regulator /bypass. Or you could have a combination of both. Try lowering the pressure to lowest setting to see if slow pulsation stops. As parts age within pump and debris hinder operation you can no longer operate at full pressure. To make the pump last, use highest pressure as needed and everyday work using only 60 to 75 percent of capacity.
Mar 19, 2013 • Garden
2helpful
My barracuda is not moving and i fell is not pulsating eather why?
If your pool cleaner is moving slowly and not pulsating, there are a couple things that you will want to check and/or adjust. Make sure that the main drain is closed. It is a common problem with these pool cleaners not operating correctly if the drain is not closed. Use your flow gauge to make sure that there is adequate flow. Poor water flow through the cleaner can cause these problems. Backwash the filter and clean out any skimmer baskets. Clogs can cause loss of suction and prevent movement. Make sure that the diaphragm is not damaged. Check for hose leaks and air entering the line at all connections.
1helpful
A friend has a oven that has been coming on with a bang. I've cycled it on and off cold and hot no problems when I was there. Pulled the botten pan out (it is quite worped from heat and dosn't fit that...
a lot of iffy things could be happening here..
verify proper amperage draw through the ignitor.. i believe thats a 3.2-3.5 amp system but check the label thats on the gas valve, it will have the ratings listed on there for sure. make sure amperage draw is in the middle of the range as some gas valves are less tolerant of low amperage draw than others.
it almost sounds like your amperage load may be on the low side, just enough to open the valve regularly but not open fully..
its on its way out if so..
the popping could be the gas coming into the oven slowly enough to NOT blow directly across the ignitor properly, (igniting it instantly if it were) and allowing it to pool in the enclosure some because of the low amperage draw through the ignitor, eventually firing with a bang..
yes the regulator vent could be plugged, but another thing is if you are on bottled gas/lp/propane for your source of fuel the regulator at the tank could be faulty also, causing the pulsing flame..
hope this helps,
best of luck,
ttfn
Hi Is the LED supposed to pulsate, i am not getting any output from the subwoofer
no, the led is not supposed to pulsate. this means that either you have a bad ground, or your speakers are going bad. if the voice coils in your subs are getting too much power, they will slowly burn out until they short circuit. i had the same problem with two rockford fosgate p1 subs on a boss riot 2500 amp.
Pulsating or flickering lights
your car is in denial.... Have your battery load testest. If it has any plate issues it can mislead the alternator regarding its state of charge abd, by all means make sure your battery cables are clean and tight. good luck
Kenmore 80 series model #110.26882503 fills slowly
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Pulsating Picture
Your set might have loose conections ,a few places to check is the horizontal driver transformer and the convergence IC's,they develop loose conections and need to be resoldered,if you are familiar with tv service and soldering is something you could do ,some conectors might get disconected when you flip the board,but if you are not too familiar I would suggest you call for assistance from a servicer.Besides the places I mentioned I am sure the set has other overheated places that need resoldered as well.Let Us know how it goes.
Top Universal Pool & Spa Experts
ADMIN Andrew
ADMIN Andrew
Jay Finke
Jay Finke
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
