Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Z 550 reidge internal leak
Hi, My old sub zero 550 has an ongoing problem of. The bottom of fridge module keeps filling up with water. Door fits and seems to seal well.(after closing, takes about 10-20 seconds to pull open again) Been a bit hot and humid here lately (So. Cal). But nothing top severe. I heard this was a common problem du to the drain freesing up and that Sub-Zero had a fix, some sort of heating element. 1) What Is this part called ? ? part #? 2) Where is the opening to this drain and tube (?) located? 3) A small amount of water is also spilling out on the floor (the drain pan is positioned right and the element is warm (last I checked) 4) Any other explanations for the water problems? Thanks in advance. Peter
  • croak2 Aug 23, 2007
    Pretty sure if the drain is pluged it's with ice. happpen before, unpluged and before to long it happened again...learned to live with it.
    Is the defrost sensor part of the fridge or freezer? I ask because I accidently left the freezer door open alnight on a humid nght and the dischare side of the evaporator completely froze up...block of ice.
    THANX, Peter
The tube behind the crisper drawers is not insulated well enough and will repeatedly freeze, leaving the water to drain on your floor. The solution is to thaw the tube and put a piece of copper the length of your tube, into the area below. The wire extending into the area below is just warm enough to keep the tube from freezing.
Posted on Jun 17, 2008
  • 183 Answers
Defrost sensor not working or drain tube blocked prior to drip tray. Regards Advisor
Posted on Aug 23, 2007
  • Tony Coultrip Aug 23, 2007
    The defrost snsor is in the freezer,this style of unit suffers from doors being left slightly open or closed against a drawer or contents, often the problem you have does not show up for several days after the initial event, try defrosting overnight before replacing parts I see many of these usually defrost and all works ok untill the next time.
    Regards
    Advisor
Why is Water leaking out of the bottom outside corner of my sub zero fridge
I would guess your drain is clogged and leaking. Without a model number I can't instruct you where to look and correct this issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 12, 2014 | Sub-Zero Refrigerators
My sub zero fridge is leaking water. The drain at the bottom of the fridge is blocked and the water overflows and eventually flows out when the door is opened. How can I unclog this drain. This is a...
use a syringe with clorine bleach to unblock the drain.and check that the door seals are touching all round otherwise you will constantly have a frost problem.
Oct 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
Hi. My Sub Zero 632 is dripping water from the bottom corner of the freezer door. Can you tell me what the problem is and how I might fix this? Thank you so much.
It does appear that your side by side refrigerator has an ice maker, so that rules out any extra water from a faulty valve.
I think the seal on your freezer door may be broken/torn.
Usually there is no water (per se) in the freezer, but as things thaw, or as the door is opened it can create condensation that leaks. The freezer will retain cool for a while but eventually things will thaw out and water will leak.
Please check the thermostat for the freezer, and make sure there are no containers leaking in the fridge portion.
Good luck.
Sep 26, 2010 | Sub-Zero 632 / S
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
673 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
