-   I have a compaq presario 3000. I am on it right now, and I can see the screen but there is no real light. I have my lamp with the shade off so I can see the display. I also noticed that in the past 10 mins I see a flash of light, almost like if you were to be in a storm and the power goes in and out. It seems like it could be something like a short or bad connection. If it was a bulb of some sort wouldn't it just go out with no flickering of light at all? I tried a few different things like system restore which I knew that wouldn't help but I tried, I unistalled something that I downloaded from the web, it is possible the problem happened right after that, In my device manager there is yellow question marks on other devices. When I open that it is 5 different things that have yellow marks, each of which say need the driver, the last one is vga compatible.
Thank you to anyone w/input. -   Nicholerose
Have you tried to connect it to an external monitor? It has an external video out. If it does, at least the video cards working. Then, as rebel 245 suggested, if you see a dim image, or no image determines whether you need an inverter or an lcd. Also, it's possible that the cable needs to be re-connected to the lcd. Good luck
I had the same problem. I had to send mine in for a new inverter. Try tapping the small white button on the top right of your computer. This will refresh your laptop display and may work for a while. Otherwise hook up an external monitor and hit the FN and f-4 keys simultaneously, that will send the signal to an external monitor.FYI If you hit the keys again the video signal goes to both , again and the laptop only.
with the notebook on shine a light onto the screen and see if you can see anything, if you can then its you backlight that has gone out. if you can't see anything. it may be the power inverter
Hi everyone Many thanks in advance for helping me fixing my acer travelmate 4052 laptop. One fine...
(More)
Hi everyone Many thanks in advance for helping me fixing my acer travelmate 4052 laptop. One fine day it decided not to work. The initial problem was it was failing to boot. Soon after the power button is switched on the power light will be green, the hard disk drive (HDD) activity indicator will glow for a few seconds and then the HDD indicator will turn off.But the power light will still be on.
Then there will an absolute silence and if left for about 10 -20 minutes the computer will start to boot slowly - sometimes it will boot fully otherwise it freezes in the middle. If it boots fully then it will allow me to work for 15-20 minutes and it will shutdown automatically or it will just freeze.
If it freezes the only way I could turn off is to switch the power button off. (I noticed the HDD activity indicator will glow as long as I am able to work on the computer and then when it freezes the indicator will switch off, but ht e computer power light is still on) I tried to reinstall my windows XP with no great success. I have read something on the internet and I tried several tricks including running my windows task manager with no effect. So i left the laptop for a couple of weeks and switched on again today and it did the same thing - failed to boot. I tried for the second time and when it booted after 20 minutes, I decided to leave my windows media player ON this time and to my surprise I was able to work on it for half an hour (longer than usual) and it did the same again - either it will shut down suddenly or it would freeze. I am not sure if that was a coincidence when I played the media player but consistently I was able to work on the computer longer (since this problem) if I leave my media player ON. Will you be able to tell me if this could be fixed. I will really appreciate if any of you could explain in simple terms as I am not that computer literate. Many thanks for your help Regards VS
My laptop keyboard hasn't been working for about 24 hours. At first, my laptop shift key seemed to...
(More)
My laptop keyboard hasn't been working for about 24 hours. At first, my laptop shift key seemed to be stuck because I was typing in all symbols instead of numbers like # instead of 3 or & instead of 7. Now I rarely type at all. If I open up a browser click the address bar and start typing with "www.." my browser closes, I believe it's typing in commands. I don't know if this helps but I just got the computer October 18th. Thanks.
I have an Acer Aspire 9410 laptop with Windows Vista Home Premium. The computer has a webcam device...
(More)
I have an Acer Aspire 9410 laptop with Windows Vista Home Premium. The computer has a webcam device included inside, but it doesn't appear to be working. I need some help. Is there a driver that I need or something?
my laptop keeps on getting to the windows screen and then failing and it gives me five options 3...
(More)
my laptop keeps on getting to the windows screen and then failing and it gives me five options 3 different safe modes and the last good config, and then start normally i tried all of them and they all just brought me back to the same screen i even did the f8 advance things and those didnt work either PLEASE HELP I NEED THIS COMPUTER WITH EVERY I DONT WANT TO GET RID OF ALL OF THE FILES AND IT DOESNT HAVE A DISK DRIVE
