Microwave Ovens Logo
Anonymous Posted on Jun 07, 2013
1515w Need to locate replacement part: harness for undercabinet lights plus 2 bulbs
William Miller
Level 3:
  • Goldstar Master 9,179 Answers
  • Posted on Jun 10, 2013
William Miller
Goldstar Master
Level 3:
Answers
9179
Questions
Helped
4480731
Points
21747
You can order Goldstar / LG parts from Encompass here or you can call them toll-free at 866-779-5835.
The model number would be MV-1515W if it's white, and MV-1515B if it's black, but those parts will be the same in both versions.
If you're having trouble with the cooktop lights either staying on or not coming on after they have blown and been replaced, your need your control circuit board repaired. Details are here.
How do you change the light bulb in outdoor light 68D44
Is your 68D44 lamp the Califa 21 1/2" high bronze textured outdoor post light, https://www.lampsplus.com/products/califa-21-and-one-half-inch-high-bronze-textured-glass-outdoor-post-light__68d44.html . There are four screws that hold the frame (the top section) to the body. These are close to the top of the body of the lamp. Once you remove the screws, lift up the frame part of the fixture. Now you can remove the bulb and put in a new one. Place the frame back on the body of the light and replace the screws. See the Figure 1 in the manual, https://www.lampsplus.com/products/califa-21-and-one-half-inch-high-bronze-textured-glass-outdoor-post-light__68d44.html# , to see where to locate the screws on the unit.
I hope this helps.
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Kenmore elite microwave convection 721.67903 light bulb
27oct: BKOK, replacing the light bulb is not simple, and requires a T15 security bit. Our microwave bulb blew this week, and sears on-line was not helpful, so I took the cover off and removed the bulb and the filament is blown. Here is what you need to do. Sorry, it's not easy. 1) remove the cover - this has 3 standard black phillips head screws, 2 on one side and 1 on the other. Then, there are 4 standard silver phillips heads on the back, plus two size 15 Torx screws that require a security bit to remove. 2) remove the 3 sided cover by prying the bottom and then pushing the cover towards the back of the unit to remove the latch keeping the cover secure to the front of the machine. 3) Now, there is a wiring diagram on the cover, use this to locate the bulb, but I will tell you it is on the top of the unit near the control panel. The white plastic connector has 4 wires going into it... Red, Yellow, Brown and Black. The bulb is secured with one screw and permanently attached to a trapazoidal base. The markings on my bulb say KEI, Korea, 125V,30W. 4) Remove the screw and lift the bulb assembly out and see if the filament is blown. The bulb is clear and so it's easy to see the filament. 5) I'm gonna go to local repair shop to see if they have replacements, but I usually go to AppliancePartsPro. They do have this bulb listed for under $5. , which is ok, but I hate paying shipping on such a small piece. Maybe I'll buy some other stuff. Good luck, it's not easy, and not a easy do-it-yourself bulb replacement. But if you are mechanically and electrically competant, it's not bad. But seriously, this is a lot of work to replace a light bulb. I'll take a picture and post that as well
1helpful
Riccar microwave oven RM 700N Light no longer works - can't figure out how to get to the bulb to replace it.
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to remove the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
Ge spacemaker microwave Model JVM163OWB 003 the undercabinet light was out, so I changed it, it appears to have shorted out, now the oven and turntable stays on all the time and the undercabinet light is...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
[email protected]
http://www.microwavedisplay.com
PEB1590sm1ss light bulb change. 1) Cannot find the light bulb location (believe upper right) 2) How do you change the bulb? Broke down the unit until it I ran into a screw type that cannot work with.
Even though this post is older I will state how to replace your oven lamp. First you have to remove the outer casing a couple of philips head screws and 2 torx head screws. Next in the middle you will see the oven lamp you have bend down to see it is hooked up to a wire harness. What I did was take the screw out first holding the oven lamp assembly then wiggle the assembly out of where it is held. Now disconnect the harness and there you go. Replace lamp and reverse the instructions and now you are set to go. No reason to call a GE repairman total time est. 15 to 20 minutes.
GE profile spacemaker XL1800 undercabinet microwave - how do you change the 2 lightbults under the microwave. I can't get the bulbs out.
There are several screws on the bottom panel that can be removed. After you remove them, the metal plate can be removed or just lowered at an angle. Using a flashlight, you will see the two bulbs that probably need replacing. Pull the wire down, and they can be easily removed and replaced.
Hope this helps.
The light is not on in the microwave when I open the door
Depending on the model, you might NOT be able to replace the bulb yourself.
With many microwave appliances the bulbs are located in a secure area away from the cooking area of the machine. If you look inside the oven, you should see an area that looks like a grill of sorts. This is most likely where the bulb is located and might not be readily accessible for you to replace unlike a conventional oven light bulb is.
Verify first where the bulb is located. If it is located in an enclosed area of the oven, you might need to call for onsite service from Whirlpool to replace the bulb. Most likely this is the case. And you should ask yourself:
1- Is the unit in warranty still?
2- If YES, then call Whirlpool Service to have it worked on
3- If NO, then ask yourself, how much do I really need a light, because to have someone come out and service the unit will cost about $100+ USD to get it working again.
I know this is not what you wanted to read as a solution, but it might be the only thing to do. There is no listed part number for a replacement bulb therefore, it is a service installable part only.
Hope this helps you out.
Cheers,
Keith
Top Goldstar Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
