Question about Acer Aspire 5003WLMi Notebook
Removing old/Installing new optical drive?
I'm in the middle of replacing my defective DVD burner in my Acer Aspire 5003WLMi laptop, but I can't for the life of me get the optical drive out. Does anyone have any information on how to remove the defective drive? Thanks to all who can help :)
  • 1 more comment
  • chrisking69 Aug 19, 2007
    Thanks for the help Atlasuk2007. I uploaded a picture which seems to have a locking screw for the optical drive, but even with the screw removed the drive's still good and stuck. Do you happen to know where I can find a guide on how to take the notebook apart? Acer isn't very good at offering things like that, so has anyone online my with notebook or a similar one written a guide? Thanks again.
  • chrisking69 Aug 20, 2007
    Thanks atlas. Well, I reefed on the drive good and hard, and managed to yank it out. But, from the looks of the drive it appears to have had a hidden screw, accessible only by removing the keyboard. But I was able to pull the drive out without removing the screw, which resulted in a broken screw holder on the drive. Luckily my new drive doesn't have any securing screw like that so I won't have to take the notebook apart.
    There will be a drawback with this however...my burner will not be secured to the notebook other than being plugged into the port...
    Oops, well it appears the old drive has a plastic detachable bracket around it, which can be removed and attached to my new drive. So now my new drive can indeed be more secured. :)
Found that acer optical drive removal require removal of key board , there is a screw located there that releases the drive when then pulls out easily.
Posted on Aug 29, 2007
    Scholar:
  • 85 Answers
Hi chris, best thing is to get hold of a manual but since NEC's support is not that good they don't provide them on their websites for download. but not to worry, generally you got 2 options from my experience i can confirm that the first one is the old drive is secured with a screw located in the back of the laptop underneath the drive itself if that's the case just unscrew it and release the old drive , the other option is you might need to strip the laptop down and unscrew the drive from inside the laptop i guarantee you these are the only ways manufacturers secure optical drives to laptops. hope this helps
Posted on Aug 19, 2007
  • 1 more comment
  • atlas  repair
    atlas repair Aug 19, 2007
    sorry i meant ACER no NEC but both of them are as bad as eachother when it comes to customer support :)
  • atlas  repair
    hi chris if yours looks like that just pull it a bit harder as it's plugged in a socket and might take some persuasion to release try this and let me know how you get on
  • atlas  repair
    atlas repair Aug 20, 2007
    well done chris
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
http://doube.org/aspireoptical
http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
http://www.batterystyle.com/acer-aspire-5000-drive-p-307461.html
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
My cd/dvd drive is unable to detect any cd/dvd.acer aspire 4520
I do have the same problem, my laptop doesnt detects the DVD writer, checked with the acer support, asked me to check the motherboard and may need to change that.
Jan 31, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My laptop wont read cds or dvds
Check with a bootable OS disc.
If it reads then repair the os
If the same issue is there, go for the replacement of Optical drive
Aug 27, 2009 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Removing metal slug to install an optical drive on an Acer deskto
It will have to be bent until the metal gives. It is like those old toys that come in the grid that you have to bend and snap off.
Apr 09, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Upgrade acer aspire 3000 optical combo?
Yes you can Upgrade by changing the whole device to a DVD writer.
Mar 20, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 5003WLMi PC Notebook Wireless driver
Try Acer Europe, they actually have drivers, where the US Site usually refers you to Microsoft or to put your Vista disk in the drive.
http://support.acer-euro.com/drivers/notebook/as_5000.html
Hope this helps.
Dec 19, 2008 | Acer Aspire 5003WLMi Notebook
Dvd/cd/burner not working
Hi 2901mslisa
Try solution from my other post http://www.fixya.com/support/t3180061-see_dvd_sometimes I think this model has a low quality optical drives, which is susceptible to defecting.
Apr 28, 2008 | Acer Aspire 5100-3357 Notebook
Acer aspire 3680 could not load dvd driver
Let me guess...you tried to install Roxio or another burner, and then it did not work, so you uninstalled it, but now your dvd drive has disappeared. You have tried to update the drivers, but you get a message showing that you have the latest driver, but alas, no dvd drive.
Use the restore point created just prior to installing the burner software and you will be fine. I have fixed 5 Acer 3680 laptops in the last two weeks with this problem. If you want to use Roxio or another burner software, go to the Acer webpage and link from them. Peace and good luck.
Nov 20, 2007 | Acer Aspire 3680 Laptop
Nti cd & dvd maker 7
try with other dvd writeing software like nero or roxio or you can try your own nti cd & dvd maker by re-installing bye
Sep 23, 2007 | Acer Aspire 5003WLMi Notebook
Acer Aspire 5003WLMi Notebook Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
