Question about Cyberhome CH-DVD 300 DVD Player
Bad Disc - CH-DVD 300 DVD Player Problem
My player is not playing. After inserting the disk its spinning for sometime and Displying Bad Disc. I have tried will several CDs DVDs, all of them cant be corrupt. Pls help me out quickly.
  • Anonymous Feb 15, 2009
    no matter dvd i play it comes up bad disc
  • ironcloud220 Feb 25, 2009
    my dvd player only plays about 3 mins into every movie i own and then freezes up on me. I would like to know whay i can do to fix it. When i bought the player 3 yrs ago it was perfect and played everything.
Goto the following site: http://www.drx9000repair.netfirms.com/#Cyberhome%20CH%20300 You more than likely have a bad power supply. The caps in the output circuit are pretty crappy and are well known for failure. Good luck! Art
Posted on Aug 22, 2007
SOURCE:
MY CYBERHOME DVD PLAYER IS READING INSERT DISC AT ALL TIMES AND WILL NOT PLAY ANT DISC. HOW TO RESET CYBERHOME 300 DVD PLYER?
I am sure problem on Laser,may be it does not read any disk.So all times it say insert disk.You can better opportunity replace this damage laser.
Aug 10, 2010 | Cyberhome CH-DVD 300 DVD Player
Why does my player display
Sorry, the player is dieing. i had this player with the same problem.
Jul 05, 2010 | Cyberhome CH-DVD 300 DVD Player
My player won't play. It always says.
There are two common problems that occur with the CH-300 DVD player. Either the machine will not power up at all and the power indicator won't work or after a disk has been inserted the on screen display will say "loading disk" but then say "bad disk".
First remove the top cover secured wih screws, you will now be able to identify the power supply board. At the output connector measure the 5 volt output with a voltmeter. If less than 4V, than the unit will not work properly. The filter capacitors are bad. Replace C10, [email protected] 10V and C11, [email protected] 10V. Because of the limited space provided, use capacitors of the same physical size. Do not try to pigtail a larger cap in its place. The circuit will not operate properly. I can supply these if you can't find them locally.
Mar 28, 2010 | Cyberhome CH-DVD 300 DVD Player
THE PLAYER DISPLAYS BAD DISC.
You have not said the TYPE of CD or DVD you are trying to play.
Your manual will clearly state what can be played and what cannot. ALSO, some mfg's like mine (samsung blu-ray) provided software or firmware updates you can d/l to flash drive or burn on cd and insert.
Check manual and your mfg websit for what's available.
May 20, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Bad disc
I have the same problem with some of the Discs I have burned. Most people say the power supply, but I have 2 of these units so I swapped the power supply to see if that was it. The problem stayed in the one machine, ruling out the power supply.
Aug 26, 2007 | Cyberhome CH-DVD 300 DVD Player
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
May 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Bad disc or insert disc problem
If you are using a copied disc try a real one. But this model of DVD Player is made so cheap. it sound like the laser assembly is bad or the motor that spins the disc is stuck or going out. If you are good at electroninics you could take the lid off load a disc and see if it spins if not give it a spin clockwise and see if it takes off. You probably should replace unit for price of a new one.
Dec 31, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
527 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
