I want to connect my existing subwoofer to my kenwood kac-7201 car audio system. My subwoofer has two input wires each accepts one single wire. To which points on the kac-7201 kenwood amp should I connect these two terminals and how?
I appreciate your help.
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
GM09SR installed April 2009 in 2006 Trailblazer, Radio sometimes will not turn on/off when key is...
(More)
GM09SR installed April 2009 in 2006 Trailblazer, Radio sometimes will not turn on/off when key is turned on/off, the chimes quit working, etc. When this happens I can "reboot" by disconnecting the car battery cable, after which the Chime and other functions return to normal. Radio used with this is Sony MEX-BT3700U, replacing GM factory basic radio (no bose, satellite, etc) After disconnecting power at battery I have to re-enter all the radio button station presets, bluetooth pairing, etc. Is there a known specific cause, and solution other than disconnecting battery cable?
i was driving down the road and the adio just shut off on my kvt911dvd. no noises or electrical...
(More)
i was driving down the road and the adio just shut off on my kvt911dvd. no noises or electrical smells, it just quitely shut off. it still works fine and the video will still play just no sound. any suggestions
