Question about Acer Aspire 5002WLMi Notebook
Loud Fan My acer aspire 5002 laptop fan is really loud and annoying. I was wondering if there was anyway to quieten it down, also it stays on almost all the time even if i'm not doing very much. I thought maybe it needs to be lubricated but i'm not sure exactly how to remove it.
    Brigadier General:
  • 6,966 Answers
Hi, I am afraid that your problem is common to this laptop brand/model. A reason is that it uses AMD Turion64 with reported nominal operating temp at ~50.0?c. At ~55.0? the CPU fan will kick in until the temperature stabilizes which unfortunately takes a long time due to the nature of the enclosed spaces in a laptop. Also lubrication will help improve the fan but will not solve the noise nor the turning on quickly, other than it's a complicated and tedious job opening the unit. Other users of the same model reports positive results by lowering the supply voltage of your process. The process is called "undervolting" and best described in Mr. Dan Zhang's guide at http://www.laptoplogic.com/resources/guides/38/1/1/ and tried at http://forum.notebookreview.com/showthread.php?t=20249. Hope that this give you an idea and pls post back how things turn up or if you need further information. Good luck and kind regards.
Posted on Aug 19, 2007
SOURCE:
Fan makes really loud noise and then computer shuts down by itself i have an acer aspire4530
sounds like the machine is overheating, remove the case and clean out the fan and surrounding area.
May 02, 2011 | Acer Aspire One PC Notebook
I have an Acer Aspire 5735Z. The cooling fan works intermittently. I am not sure if I need a new fan, or the problem could be more serious. Thanks for any help. [email protected]
sometimes the fan races if you like, sounds loud, then when its cooled the comp down, it stops or goes slowly, until comp gets hot again. hope this helps, make sure you always rest the computer on a hard solid surface never a soft 1 like beds or cushions ect.
Apr 27, 2010 | Acer Aspire One PC Notebook
My Acer Aspire One AOA150 's fan is very loud and warm
I'd suggest that you carefully pull the base of your Acer apart - taking out the screw, and keeping track of them. See if your fan is dirty - I have an Acer as well, and if it's dirty, it get loud, and HOT!
A quick cleaning does wonders!
Feb 15, 2010 | Acer Aspire One AOA150-1784 Netbook
Aspire 5315: Loud, Long, High Pitch Beep During Start Up
you need to replace the memory..or try to make clean using a Paper Eraser for make a clean the memory..clean the all pin connectors..good luck
Jun 13, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5515 fan is really loud
need to open the lappy if no warranty and clean the air contision fan
Mar 07, 2009 | Computers & Internet
Acer Aspire 5002 Laptop will not stay on
If it's spinning it's working - if it's not - then it's broken.
Aug 15, 2008 | Acer Aspire 5002WLMi Notebook
Running loudly
this sounds like the fan
Jun 30, 2008 | Acer Aspire 5100 Notebook
CPU Fan
depending on the size of the fan you can probably remove it and take it to your local computer store and have them get you a better one of the same size.
Nov 19, 2007 | HP Pavilion a1010n (PS563AA) PC Desktop
Acer 5002 laptop shutoff randomly
Have your DVD Rom checked..I had a similar problem XP not loadin... It was because of compatibility of the rom... like wise it could be a mother board problem..
have it checked up by an acer service person
Oct 16, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5002WLMi Notebook Logo
129 people viewed this question
Ekse
Alun Cox
