Question about Hitachi 43FDX01B TV
Hitachi 43FDX01B Green Line Not Alligned
This Tv worked great until my little one hit the side of the tv and now shows double-like picture! HELP! I tried to adjust and when that button is pushed the green line that goes up and down is off to the right side but the lines side to side are fine. How do I fix this??? Can anyone talk me through it or give me instructions Please,Thanks!!
  • papab3ar Dec 16, 2007
    I purchased my Hitachi 43FDX01B many years ago and it has been working fine until 2 weeks ago when the color green went awry I have attempted to perform a convergence alligment, but couldnt figure out how to move the lines. The Green line is off to the right of the centre, with it splitting mid way down, forming 2 lines. Can anyone help!!
  • 398 Answers
If you slap the set on the side and the colors shift and dont line up, it is most likely that one of your convergence IC's has cracked solder joints. It is also possible that the IC has burned out. The convergence IC's will have to be resoldered and possibly replaced, and that should be done by someone with experience in repairing and realigning convergence circuits in projection TV's.
Posted on Aug 19, 2007
SOURCE:
A line of the pic is showing and i have to hit the side to get it to work
There is some loose loder points at the vertical output section of the set. Find them, and resolder them by applying a little more solder.
Mar 27, 2012 | Hitachi 36UDX10S 36" TV
Hitachi Model# 43FDX01B is doing a double image.
You have a convergence problem, you will need to change the convergence IC's STK392-110, there is also 12 6.8 1w resistors that need to be changed, there is also 2 fusilbe resistors that may be open. You can probably Google the IC's as a kit and find them all in one kit.
You can fix this yourself and save about $300-$400 in repair bills.
Feb 23, 2010 | Hitachi 43FDX01B TV
Color has changed to green tint
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Jan 09, 2010 | Hitachi 43FDX01B TV
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
Feb 18, 2018 | Hitachi 43FDX01B TV
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is [email protected] thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
as the problem cannot be the rectified by the user. as it may require authorised service personnel. the problem might be with Tuner,video processing circuits. also mainly with the deflection circuits
Dec 20, 2007 | Hitachi 43FDX01B TV
Red Lens off on Hitachi projection tv Model 43FDX01B
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 05, 2007 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
