Question about Zenith A32B41W 32" TV
Zenith A32B41W Ground
I have a Zenith A32B41W TV, Circuit PCB 9-2003. I discovered two bad 1000pf/2000v caps, CX3220 (fried) and CX3231 which I have purchased replacements. But I also discovered what looks like some type of ground fuse or plate (EX3401) next to the AC Input that has definite visible signs of arcing/damage. Should I replace this? I was reading a similar post and it discussed finding the root cause, which I did, but it did not mention replacing this. If so, what is the part# and where can I find it? Also I discovered a loose component (THX3415). It looks like a silver disc (the loose part) sandwitched between two wire leads. This component is in the same section of the PCB. What is this? Some kind of thermal component? I am assuming I need to replace it as well. Any part number and place I can purchase? I cannot locate a schematic for this board. Any help is appeciated. Arnie
  • Arnie2448 Aug 20, 2007
    Thanks MikeNJ! Replacing the two caps worked. I was able to resolder the thermistor and everything else worked fine. Thanks again for the help.
  • 398 Answers
The 1000pF 2KV caps in the Zenith sets are notorious for burning up. I have seen it many, many times. The ground "plate" you describe is a dual spark gap, between the tuner ground and each side of the AC line. This part literally does nothing until a bolt of lightning hits very close to your house. Even if it shows signs of arcing, it is still good and does not need to be replaced, unless it has melted into a blob of goo and that never happens. The silver part you describe is the degaussing thermistor. It only works for the first half-second when the set is turned on, demagnetizing the picture tube. If you do not replace the thermistor, it is possible that when you move the set you will see that the colors are not quite right in the corners of the picture. If you are careful you can solder the legs back onto the thermistor, but they love to crack when heated with a soldering iron. Bring the broken one to your local TV shop and they will most certainly have many new ones in stock.
Posted on Aug 19, 2007
Need to know the value for Capacitor CX3211 on the edge of the board. The CX3212 next to it reads HR R 561K 2KV and I wonder if they are the same. THe CX3211 burned and the TV died. I am layed off and...
The value of CX3211 is 1000pF 10% 2000V, ceramic disc.
You can also download the service manual from this website. Make sure to download all the 7 files.
Good Luck.
Jul 26, 2009 | Zenith B27A11Z 27" TV
TV went "pop"
prob not worth repair sounds like horiz sweep circuit. 150 200 to repair.
Nov 30, 2008 | Zenith A32B41W 32" TV
Hello Again
Here are the values:
CX3231 022-08386-01 CAP, 270 PFD 10% 2000V, CERAMIC DISC
CX3220 022-08386-08 CAP, 1000 PFD 10% 2000V, CERAMIC DISC
Will send you the service manual if needed.
Aug 21, 2008 | Zenith A27A11D 27" TV
Burned capacitor?
If it is CX3231 it is a ceramic disc capacitor 1000 picofarad, 2000V.
Dan
May 19, 2008 | Zenith A32B41W 32" TV
Zenith A32B41W 32
They are labeled 561K 2KV, stands for 560pF (pico Farad) 2000volt.
You can easily get replacements from Digi-key, Mouser Electronics, Allied Electronics, Newark Electronics, and many other places. (sorry, your local Radio Shack doesn't have them.) I suggest that you get 2500-3500 volt as replacements as that's probably what they should have been in the first place.
At Digi-Key I found part number 490-4141-ND, 3.15KV replacements at $0.33 ea., the shipping will be the biggest part of the cost!
Jan 07, 2008 | Zenith A32B41W 32" TV
Zenith A32B41W (part # for CX3231)
I might be able to help you but I need to know what the part is. My email address is wyoed1@aol.com or send message back at this address.
Ed
NC Electronic
Mills, Wyoming
Zenith A27A11D Power Problem
replace it and also the power regulator
Nov 19, 2007 | Zenith C27A24T 27" TV
Zenith A27A23W 27 Capacitor CX 3231 blew up
The little blue caps that burn up are 560pF 2KV caps
Nov 28, 2006 | Zenith A27A23W 27" TV
Zenith A27B41W
I dont see this model number under PTS corp list of Zenith's modules. But a service manual is available from http://www.servicemanuals.net For a download. If you know how to work on solid state electronics, then you should have no problem with this repair. If your a handi person, a TV set is no place to be experimenting around inside of as it can seriously kill you. Find a trined tech to assist you with this. Good Luck
Aug 26, 2006 | Zenith A27B41W TV
Televison & Video Logo
242 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
