Question about Liquid Video E17LCD1 17" Flat Panel LCD Monitor
LCD blinking on and off continually
Hi, my problem is that my LCD blinks on and off, on and off, on and off, and so on. I have tried unplugging it from both power and the computer but it continues to blink on and off. Any suggestions would be greatly appreciated. Thanks.
  • vickie6971 Jun 02, 2008
    mine has been doing the same thing and then it says No Signal Input, then shuts down. I do believe it's time for a new monitor, I have had for about three years or so. Mine is a A17OE1-01
    Scholar:
  • 76 Answers
If it flashes ON and OFF when simultaneously unplugged from both power and the computer then it's trying to communicate with you. Mine flashes code to me. It tells me what to do. Last night it told me to get it $5,000,000 in unmarked bills. Seriously, turn the monitor on without connecting it to a computer. If it flashes ON and OFF continously, then you have either a bad monitor or a bad AC/DC power adapter/brick (you know, the rectangular black corded adapter you plug into the wall outlet). If it only flashes ON and OFF when connected to a computer, try the monitor on another computer. If the monitor is 3-4 years old, it may be time to replace it since a replacement AC/DC adapter might be very hard to find. Let me know what you find out, if you need more help. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
  • Stevie Wonderboy Aug 19, 2007
    Sidenote:
    Now that I've had a refreshing night's sleep and can think better, I mentioned the AC/DC adapter above, I don't really think that is the problem in your case.
    What I believe is wrong in your case is:
    the flashing ON and OFF is normally caused by a bad ballast capacitor on the inverter printed circuit board (PCB).
    This can be replaced/repaired by a competent technician, although I'm sure the repair and shipping costs would almost equal 3/4 of the purchase price of a new monitor.
    Time for a new LCD?
    ZT3000
SOURCE:
The red light is on and when I try to turn the TV on it flickers as if to come on and then nothing.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 05, 2015 | Funai 32MF339B 32 in LCD TV
Mitsubishi LT-46149 power lamp just flashes and tv will not turn on. Tried the reset and unplugged overnight, also I do wait for the "boot up" still just have a flashing power lamp. Any ideas?
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 24, 2014 | Mitsubishi LT-46144 46 in. LCD HDTV
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
The tv's green "on" light continues to blink on and off. when we turn it on at the remote or at the on/off switch on the side, it won't turn on. we have unplugged it and the light continues to blink. We...
Try pressing and holding the remotes "Power on" switch as it may be a child lock that is activated. Otherwise try holding the tv "Power on" switch. Hope this helps.
Jun 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Red light blinks twice tv doesn't come on
Sony Blinking Codes:
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Try checking the power supply,
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 15, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
Power light blinking RED after power outage. Tried leaving unplugged for a while. Continued to blink RED after plugging in again. No picture. No sound.
replace the power pcb,check the fuse on the
power pcb and see if that corrects your problem.if not replace the power pcb.go tp
shopjimmy.com to get the board.
Jul 29, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Sharp 19" LCD blinking red light
Your tv needs servicing, it has developed some kind of circuit malfunction. You can send it too me for fast repairs and return. Or find a shop in your area.
e-mail me...
Feb 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Open Questions:
See all Liquid Video E17LCD1 17" Flat Panel LCD Monitor Questions
Liquid Video E17LCD1 17" Flat Panel LCD Monitor Logo
333 people viewed this question
Top Liquid Video Computers & Internet Experts
Ekse
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
