Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
3.5 hard drive enclosure
Have used new & old hard drive but its won't mount. Used on XP & Vista. Installation disc won't work & error message says it's a plug & play but it doesn't. What's next?
  • SchirmD Mar 17, 2008
    I installed a Maxtor 120GB hard drive into a Nexxtech 3.5" enclosure. It seemed to work, both my laptop (windows XP) and desktop (XP home) recognized it as a USB mass storage device, but the drive would not appear in My Computer. I tried setting the jumper to master and slave, as well as Cable Select, all to no effect.
  • 3 Answers
I'm so frustrated. I must of messed around for 2 hours too until I read the last post about setting the jumpers to cable. that worked! thanks bro
Posted on May 29, 2008
Bro I just setup a nexxtech 3.5 inch external enclosure. Their instructions say to set the jumper to master. It doesn't work with master. After two hours of screwing around with it I set the jumper to cable select and it worked perfect. Im using a maxtor 160g hd.
Posted on Nov 28, 2007
    Scholar:
  • 76 Answers
Try a different USB cable. Try a different computer. If those don't solve it, it a defective enclosure. I seem to have a handful of defective ones myself. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
SOURCE:
I have the same problem the toshiba recovery disk i get error message 10f8060017.its a toshiba A105-2194 win xp media edition. i have tried everything wiped the disk to all 0's. Used a win xp original disc...
You have tried all possible solutions and troubleshooting.
My Suggestion is to check the Warranty of the Hard Disk and get it replaced. this possible shows a mismatch between the Laptop and hard drive.
Feb 15, 2011 | Toshiba Satellite A105 Notebook
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
Can't install Windows XP Home on Compaq CQ50-139M Notebook
I would run a deeper scan of the hard drive while hooked up to the SATA -USB enclosure. Try using either Seatools or Western digital Data lifegurad tools and run the long scans. If the XP CD is in fact SP-3 it should have all of the necessary drivers for SATA drives. I am suspecting some bad sectors and a possibly failing hard drive, which would also explain why Vista froze.
These diagnostic tools can be found at:
http://majorgeeks.com/Western_Digital_Data_Lifeguard_Tools_d2855.html
and
http://majorgeeks.com/Seagate_SeaTools_for_Windows_d2858.html
Sep 27, 2009 | Acer Aspire 5610-4648 Notebook
Installing XP over vista
if your asking to install XP on top of vista.. if you do not like vista, then ur listening to your friends who have no idea what their talking about because its awesome and when windows 7 comes out youll be stunned...this is verry easy if you have XP disc ready, restart your computer you need to wipe ur hard drive to get rid of the old operating system, first save any thing you want thus wiping hard drive saves nothing.... techniquly its still there but ya....put in disc of XP and run the disc to install XP,. ACTIVATE IT AND WALA
Apr 22, 2009 | Toshiba Satellite® A205-S5841 PC Notebook
Drive not recognized under Vista Home Premium 64-bit
I have seen drives not recognized for a few reasons. Bad drives, drives not jumpered correctly or full-disk encryption was used on them. Here are my thoughts:
Try making sure that the drive is jumpered to Master. Should be a jumper on the back of the drive.
Make sure you did not encrypt the hard drive using full disk encryption.
I use an USB IDE drive enclosure when recovering customer's data using a Vista computer and have not had any issues other than the ones mentioned above.
Let us know if this helps or what you find out.
Mar 31, 2009 | HP Computers & Internet
NTLDR is missing
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
IRQL_NOT_LESS_OR_EQUAL
1. purchase a 2.5" usb enclosure.
2. remove your hard drive and install in the enclosure.
3. plug the enclosure into a working computer and copy or move your important files onto working computer.
4a. reinstall the laptop hard drive and try a repair installation by booting from the XP cd. (if you are running xp)
4b. reinstall the laptop hard drive and try booting to Last Known Good Configuration. Press either the F5 or F8 key while rebooting to get to the menu.
4c. purchase a new hard drive and reinstall the OS using the reinstallation cd's
Dec 09, 2008 | Dell Inspiron 1501 Notebook
My old Dell HD will not fit in HP w/vista
i see..well..was the old hard drive running xp by chance?..seems that with the new vista, that each application would need to be upgraded with drivers to pull the old data..another option is to use a data recovery service.
May 10, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
205 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
