I had a hp printer that didnt want to print I found out that if one of the ink cartridges is empty it wouldnt print. I needed to print a letter in black ink so I had to trick out the cartridge by putting black electrical tape over the small site glass(plastic) so the printer thinks it is full,after this the printer would at least print the letter
Go in the printer preferences and change the options to "print as in document" and make sure that 'scaled to it is not checked'. Maybe, you scaled it down by accident. Also, make sure that you didnt choose 8 points in the original document. Otherwise, it will print small
the pdf files you printed might be too small in letter size..check if the printer works properly if you copy and paste the adobe files in MS WORD and increase the letter size and then print it..pls feedback for this solution
Sounds like it is shrinking the fonts down to fit them on the page. You can either look for a button that will format it to print, or go into print through the print preview and set it to 100% instead of fit to page. Good Luck!
What printer is it ? Some older ones need manual calibration, where patterns are printed, then you tell the system which is the best one. Newer ones can self calibrate, but still need it done. Go into your printers menu and see if you can find something on calibration or allignment.
You normally do this in the software package that you are using to type the letters, for example Word.
If you are talking about printing from the Internet, the font size in Internet Explorer can be changed by going to View - Text size. Look at the print preview before you print.
Alternatively copy and paste the text into Word and you can format it how you like.
