Question about Maytag PAV2300 Top Load Washer
Water overflow no problems until yesterday when the water just kept flowing regardless of size setting. I replaced the water sensor and thought it was OK but after 3 loads it overflowed again. I replaced the water shutoff valve (and solenoid) but this was not the problem either. Water is still overflowing.
  • hoogy Aug 20, 2007
    I removed the clear hose to the water sensor and found a small cut right at the clamp.
    I cut off the last half inch of the hose (at the cut) and reinstalled it. Washer seems to work fine now.
    Novelist:
    Champion:
  • 244 Answers
When u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Posted on Aug 19, 2007
  • peter gittos
    peter gittos Aug 20, 2007
    that will of been your problem it will of been sucking air into it and stopping your pressure switch from reading the real pressure indide your drum has the water filled up it will have been getting air constantly should be ok now m8
SOURCE:
How do I check if a current overflow' problem is due to the Sensor or the Rainbank?
take the sensor above water level--say in a bucket of water then lift it out of the bucket
if the mains water flows or stops flowing depending on whether the sensor is in or out of the water will indicate it sensor or solenoid of the rainbank
I suspect that the sensor will be a simple float arrangement filled with mercury so that when it is hanging down ( no tank water) the mercury bridges a set of contact points and makes a circuit and when it get to a fill point the mercury flows away from the points and so breaks the circuit
Sep 28, 2016 | Washing Machines
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
Model # 110.26832692 does not stop filling up with water when the load selector size is set will overflow if I don't stop it!
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps to figure out what is wrong with your washer,
Gene
Aug 05, 2011 | Kenmore Washing Machines
Im having an overheating problem with a 2000 Chevy Caviler...2.2 engine. The coolant is dumping out of the resevoir overflow. I thought it was the thermostat, so I changed it yesterday. The problem is...
Change the cap for the overflow tank. The seal has gone bad and can no longer hold pressure, therefore it has no where to go but leak from the overflow. New cap $10. This should fix the problem.
Sep 22, 2010 | 1999 Chevrolet Cavalier
Never stops filling with water
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 26, 2010 | General Electric WHDRE526EWW Top Load...
Water over flowing
I will assume that your machine does not run. It just fills and fills until it overflows and you shut it off.
This is not to difficult to troubleshoot and repair.
There is a plastic hose that runs from the bottom of the wash tub to a pressure switch inside your control panel. This hose is flexible and between the size of a marker and an ink pen. As the water level rises, the air in the tube is pushed up into the pressure switch. When the correct pressure is reached, the switch shuts off the inlet valve which will stop the water flow.
You must make sure that the hose is not pinched, cracked, or disconnected on either end. Any of these will give the pressure sensor/switch a false reading.
If the hose is okay, then the switch is your most likely problem. It simply has 2 electrical connections and the hose running to it. Replacing it should be fairly simple and inexpensive. Good luck.
Dec 02, 2009 | Dryers
Older hotpoint washer
Sounds like a pressure switch problem not a timer. depending on the year and model they had alot of water level problems.
Apr 18, 2008 | Washing Machines
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Jul 07, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
690 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
