RCA F31317 31" TV
Problem for RCA F31317 31" TV
Need value for part R14109
By DustBust on Aug 19, 2007
I received a non-working RCA F31317 tv (chassis CTC203CA5) and after looking inside I found a burnt out resistor in the PSU.
The part number is R14109. I need to know the value of the resistor so I can replace it. It appears to be a light blue resistor
and the first color ring is yellow. After that I cannot tell the value. Please let me know anybody if you know the value. Thanks.
Best Solution
posted on Aug 19, 2007
Very Helpful)
Zt3000
Rank: Guru
Rating: 87%, 313 votes
R14109=750ohms 5% 1/4w
(Resistor(750r5%.25W/R14109/179317)
There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it.
If you need the manual, go to
http://www.samswebsite.com/photofact/pf_...
and type in "F31317" into the search field, you will several listings.
If you decide to replace it yourself, here's some more part numbers in case you need them.
Model: RCA\F25422TX41
Symptom: Dead
Necessary parts: Transistor(Q14401)
Main Voltage regulator Q14101
Resistor R14109 open.
Research indicated the flyback transformer most probably bad
\\CTC203AC4\HOT/D2578(Q14101/242224)*
Flyback(14536119A/T14401/244229)*
Main reg(P9NBSO/Q14101/244223)
\Reg(MPS8599/Q14102/147665)
Reg(MPSA06/Q14103/232218)
Hope this helps you.
ZT3000
"Beta tester of "0"s and "1's"
Comments:
Aug 19, 2007
- The resistor value is correct.
but..
Sorry about the broken english above. It was late at night and my sentences seem to be missing some words. I think I needed a reboot.
ZT3000
Was this helpful?
Yes
No
Popular Solutions for RCA F31317 31" TV
Questions and Unsolved Problems for RCA F31317 31" TV
Do you recommend RCA F31317 31" TV?
Answer
Answer
My RCA Model F31317 has intermittent picture display. The sound works but the picture will cut out... (More)
Answer
my sat went out and during the reset process I lost picture. just snowy static screen. still plays... (More)
Answer
my tv will not recinize when a cable box is hooked up to it. it keeps asking for a G-link for the... (More)
Answer
picture on my rca f31317 seems darker than normal, have adjusted to the brightest setting. any... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
