Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
Olympus D-535 Zoom camera
When turn the camera on it says that the card slot door is open on the lcd screen and it's not open. I have turned it on and off, taken out the batteries and reinserted and taken out the mini card and reinserted and nothing happens. i done them all in sequence and nothing happens. Please advise.
    Scholar:
  • 130 Answers
Look in the card slot in the side or around the edges of the opening to see if you can find a switch or little button or anything that could be stuck or broken. This is the sensor that tells the camera when it's open or not.
Posted on Aug 19, 2007
SOURCE:
I am having problems introducing the SD card into my SVP Aqua 5500
The camera takes microSD cards. Open the battery door to uncover the slot.
Feb 25, 2013 | SVP Aqua 5500 18mp Underwater Digital...
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
We have had our Olympus E-420 for a little over a year and have enjoyed the pictures it has taken. Today we turned the camera on and the screen said (CF) Card Error. We put the memory card in the...
I would try a different card if you have one. They can fail. If the card slot on the camera is bad then you will want to contact Olympus as they typically offer two years on camera bodies if you have registered your product at time of purchase. Failing that, try one of the Olympus XD cards in the other memory slot as an alternative to repairing camera if warranty is expired.
Mar 29, 2011 | Cameras
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
The door to the card slot has come off
sony DSC -930 on display, writing turn off the power and on again
Feb 06, 2010 | Kodak EasyShare Z1275 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
SD Card
did you ever find a solution?
Dec 11, 2008 | Nikon D40x Digital Camera
Card Error
then it is safe to assume there are no images on the card. But to be sure go to www.convar.com and download PC Inspector. Install the program. put card in the slot and run the programs- if there are images on the card this program will find them. Saveany to a folder then take thae card out and format it in the CAMERA and only ever format it in the camera.
May 25, 2007 | Fuji FinePix E510 Digital Camera
No image/blank screen in the LCD
the microchip is located when you open the card door. you will see a picture that says CF and if you go up youll see a black chip . use a pin or pen to push it in, close the slot door and it should work.
May 06, 2007 | Canon PowerShot A75 Digital Camera
My Olympus (C-3000 Zoom) camera problem.
Well, I did get this problem squared away. What I had to do was to format my card. Prior to doing this I grabbed all of the photos from the camera via my 'FileScavenger' data retrieval program (whew, so glad that I bought that nifty program).
Sep 12, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
