Question about Zoom H4 Handy Recorder
Creates a file but no playback, nothing on vue meter
I use the simplest recording for interviews...I've always just pushed record and I get beautiful mp3 files. Today I didn't check the meter, just pushed record, saw the red light and let people talk. When I tried to play the files back, no sound, nothing on the meter. The file menu says I have files and that they have a "size" and length. Is something there? Now I try to record myself, same thing. Nothing on vue meter, no playback. Help. This is a relatively new and important tool!
  • smarions Jun 15, 2008
    I have the exact same problem. I press record and it sometimes will record a file and sometimes not. This is very frustrating and getting worse. It used to do it occassionally, but now it seems to be increasing in frequency. I've had the zoom for over a year and use it all the time- but this problem is not good.
  • jofridurg Nov 06, 2008
    Same problem here. It starts recording, creates a file, but the file is 0 MB and nothing to listen to when played ofcourse.
    Problem Solver:
  • 8 Answers
Go to the music store where you bought this thing, or go to any music store that sells this product, and ask the young boy (I guess it'll be a young boy) to help you out with this. Difficult to now what's the problem without messing up with the buttons.
Posted on May 20, 2008
SOURCE:
I have a number of files on my digital recorder where I have recorded interviews. When I press play, it shows up the length of each interview and the countdown starts, but there is no sound, just a qu
Did any of the files ever playback with sound? You can record sounds, but that doesn't mean the recorder is picking them up. A bad connection, level control setting could be wrong.
Try to do another short recording. If you are using a microphone pull the jack out during recording and put it back in again. Then listen to the recording. If there is sound when the microphone is in and it goes when it is out, then there is a possibility that somehow you recorded the other stuff with no connection and that's why there is no sound. If there is no sound on the new recording at all, then you might have a faulty playback amplifier inside the device.
Apr 09, 2017 | Sony ICD-B200 Digital Voice Recorder
I have a teac 2300s tape deck. My problem is when i press the rec / pause or rec play the 2 meters slam to the right. They don't move while recording,but the deck will record and playback. Putting the...
The leads to the VU meters have shorted out. The fact that it only happens when you push "Record" sounds like part of the mechanism is actually causing the short.
Jul 15, 2017 | Pioneer Rt-1011l Reel To Reel Tape Deck...
Finalise a dvd created on pc using nero
you instal k m player and play your recorded avi file
May 19, 2012 | Toshiba Satellite L500 Series Notebook
I downloaded a .msf file from a Sony audio recorder. Please advice how I could playback this audio .msf file.
Hi!
It seems like you've downloaded the wrong files...
As mentioned at Sony's FAQ:
MSGLIST.MSF is a file that contains information such as the order of folders, playback order of audio files and recording date and time. If user connects the recorder to the computer, the MSGLIST.MSF files are displayed but do not delete or change these files. If these files are operated, the saved files may be broken or the recorder may not work correctly.
The right way to copy your recordings is explained here...
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Good luck and Best regards,
Pelu.
Apr 29, 2011 | Sony Audio Players & Recorders
What do you mean excel macro
is a hiden process of Excel, is like program or several steps ( like moving cursor, make calculations, moving files, is no limit what can do, but normaly is not visible, is low level programing is always used for virus spreeding.
Jan 14, 2010 | Computers & Internet
Err format while recording - 1 hour lost!
I have almost the exact same problem.
I did not interrupt my recording. I stopped recording, turned off the recorder, unplugged all the mics, turned on the recorder, listened to the first 10 seconds of the recorded track, turned off the recorder, plugged it into my mac, turned it on in USB mode, attempted to transfer the track file, and the track size is "zero kb." I ejected the recorder, turned it off and back on, and now the track says "err format" and skips to the next track.
This seems like a unique problem, as any "data recovery" software will search for deleted files instead of corrupted files. And even if the file is corrupted I have software that can read the raw wav data. However, the filesize is incorrect and obviously doesn't contain any wav data. Shouldn't it be the actual file size? How can I fix this???
Sep 13, 2009 | Marantz PMD660
Olympus VN-480 digtial recorder - can't get my files to play back
if the power is interupted or improperly unplugged from the computer, the files may be corrupted... try to play the files and while playing move them to another folder... this may get your files back... else you will need to clear the recorder by pressing stop and erase at the same time for about 3 seconds.
Jan 19, 2009 | Olympus VN-480 Digital Voice Recorder
Rewind.
You can rewind and playback only. You can only record by creating a new file.
Sep 09, 2008 | Olympus DS-30 Digital Voice Recorder
Locked file
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Zoom H4 Handy Recorder Logo
212 people viewed this question
Top Zoom Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
