Question about Actiontec (GT704WG) Router
Actiontec Frequency Been using GT704WG for a year - no problems. Bought pair of Altec Lansing speakers and can hear ticking through them (3 ticks per second). Signal coming from router. When I shut router down, ticking stops. When I touch router antenna, ticking stops. Tried moving router away from speakers - better but not gone. Can I change the frequency or settings of the router to solve this problem.
    Scholar:
  • 76 Answers
You can change the wireless frequency of the router, default is 9, check page 55 of your owner's manual (which is on your installation CD) Are you using the telephone portion of the router? There are NO settings in your wireless router or any consumer router to prevent what you are experiencing. BUT... Approximately 3 ticks a second equates to an 180hz signal. 180hz is a multiple of 60hz which is your powerline frequency. I'm suggesting that it is a noisy power feedback problem, since likely both the wireless router power transformer and the stereo power are on the same circuit. Touching the antenna changes the circuit output impedance which affects the signal. Your solution lies in one of the below, your choice: 1) Buy different speakers 2) Plug router into a different power outlet as far away from the stereo outlet as possible 3) Simply stretch the router as far away from the speakers as possible and live with the faint background ticking. 4) Buy a different router. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
SOURCE:
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
My speakers won't play with my mac computer. Do I need download a driver? Thanks, Tracey
Altec Lansing Multimedia USB Speakers - ADA 305http://download.cnet.com/altec-lansing-multimedia-usb/3000-18493_4-87599.html
if this is not the right driver
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps
Jul 21, 2011 | Altec Lansing VS4121 Computer Speakers
Sound breaks. have to fiddle with volume button
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Jun 27, 2011 | Altec Lansing VS2121 Computer Speakers
NO LIGHT - no sound altec lansinG XT1
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if this fails to fix the problem
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 15, 2011 | Altec Lansing XT1 Computer Speakers
Very low volume coming from speakers
i have exact same problem i think its got something to do with volume controller on front right speaker damn shame as the sound was awesome
Jun 02, 2010 | Altec Lansing ADA745 4 Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
Need the pairing code for bluetooth device to my Altec Lansing
Hi if your intentions are too connect your Phone to that bluetooth device , The paring code is what you make it , when you connect the two device's together , When you search for devices it will ask you to pair with that device , and you make the code anything you wish....Otherwise have a look at the manual under connection , it should have .
I hope this helped bud
Happy new year
Dec 24, 2009 | Altec Lansing iMT525
Altec Lansing VS2121 speakers ticking
Hello there
First things first
1) check cable for bad connectivity or dust. clean .
2) your board or volume control may be damage, or dust inside clean carefully ( if you can) with air spray for computers.
3) I hate to tell, .....change your speakers, may be is bad IC on board for speakers.
good luck
Feb 06, 2008 | Altec Lansing VS2121 Computer Speakers
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
Actiontec (GT704WG) Router Logo
119 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
