Question about Maytag Legacy Top Load Washer
My washer will not spin off the water
My maytag legacy will not spin out the water. The drum spins fine.
  • amy_shelton_ Mar 22, 2009
    In the last few weeks my washer has been sounding "sick" when spinning out the clothes, it has been making more noise than normal. Tonight when I come home to do laundy, I find that it hasn't spun out the water and clothes are still soaked. I can turn it on the spin cycle and it sounds fun, sounds like it is spinning, but the tub won't move. Any suggestions?
Just looked at mine the belt is broken.
You have to remove the motor and take the pump off to replace it.
28 1/4" x 1/2" Belt
Posted on Nov 12, 2008
  • 641 Answers
Check the drain hose and make sure it is not plugged or kinked. Check as well that pumps spins. Good luck
Posted on Aug 21, 2007
SOURCE:
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
The drum bearings may have failed , Or the spin motor winding in the motor burnt out ,
Or the selector switch contacts are not engaging in spin cycle
Jan 06, 2015 | Maytag Washing Machines
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Out of balance
Installed no slip carpeting underneath machine, worked fine.
Feb 15, 2009 | Maytag Legacy Series Top Load Washer
Washer not spinning and draining water
I just had a similar problem. I broke down and had a repair man come out to take a look. He pulled off the front lower cover, took off the inlet hose on the water pump, and found my two year old daughters sock stuck in the turbine of the water pump. The motor runs both the drum and the pump, therfore it would not spin, and would not let the water drain.
Everything was fine until tonight. I'm having the same problem again. I pulled everything off just like my repair man did, but no sock. I think I might wind up pulling off the whole pump to check the otlet side.
Anyone else have any suggestions?
Dec 06, 2007 | Maytag Legacy Series Top Load Washer
Maytag Legacy
Need a special tool to remove the lock nut on the spin tub
Aug 28, 2007 | Maytag Legacy Top Load Washer
Washing Machines Logo
204 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
