Question about Onkyo M-282 2-Channel Amplifier
ONKYO TX-SV717PRO Amplifiier
Stuck in PROTECT MODE fuse is o'k. Can't get passed PROTECT mode.
  • Anonymous Apr 04, 2008
    Had also a protection problem and the right main channel was silent. Poor soldering on the little bass/treble/balance was the reason for all the worry. Just re-soldered the little print-board, and any dubious looking dry-joints on the other boards.
  • David David
    David David Aug 08, 2017
    I also have this model and the Right Channel not giving signal to the main stage. Trouble is the circuitry - TX-SV717PRO isnt linear and it coul be that small board. I have seen evidence of plenty of possible dry solder joints as this model was made in Japan and wasn't robot surface mount circuitry. Looking to hear from anyone else with Right channel down???
  • 113 Answers
Disconnect power and try after 20min without speakers.
Posted on Aug 22, 2007
How do you reboot?
Posted on Nov 03, 2008
Towards the back of the users manual there is a sequence for "rebooting" the unit. That's fixed mine every time it freezes.
Posted on Sep 21, 2008
My receiver is in protect mode..what does that mean
See reasons for protect mode on onkyo site.
Most likely the speaker wires are shorting or are reverse polarity. see connection diagram.
Jan 19, 2011 | Onkyo TX-8511 Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Mar 19, 2009 | Audio Players & Recorders
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Onkyo tx-sv535
when the apm in protect mode means it is problem in inside.don't trow it please repair it n use
Jan 02, 2008 | Onkyo TX-SV535 Receiver
Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Aug 28, 2007 | Onkyo TX-8511 Receiver
Help
You need to replace the internal fuse.
Aug 25, 2007 | Onkyo TX-SV454 Receiver
Stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Aug 16, 2007 | Onkyo TX-SV454 Receiver
Onkyo M-282 2-Channel Amplifier Logo
1,813 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
