FixYa.com
Tags:
Toshiba 30HF66 30
Second toshiba tv and they both do the same thing
posted by skfm21 on Aug 19, 2007
I can not get all my channels. Only 13 channels. I have cable and should get 70 channels. I do get them on my other tvs but can not get them on either of the Toshibas. After the 13th channel it begins scanning thru all the channels but with no picture only snow. when I mannually go to a higher channel, I get only snow and no picture. What could be the problem and how can I fix it? Please give me a solution to this problem. Thanks, skfm21
Comment by skfm21, posted on Aug 19, 2007
thank you sooooooo much
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 86%, 1989 votes
It is possible that your Toshiba is set to receive aerial TV programs and not Cable TV programs.
You need to go to the set-up menu (via remote) and go to the air/cable selection. Choose cable and then auto search/scan. This is a generic procedure and should work with your particular brand/model but the terms/names may just be a bit different. You may also consult the users manual for the exact procedure.
Hope this give you an idea. Good luck and kind regards.
Rating Locked! (?) skfm21 has rated this solution as FixYa!
Solution #2
posted on Feb 29, 2008
Not Rated (0)
cycus
Rank:Guru Guru
Rating: 88%, 91 votes
all you need to do is to reprogram the tv
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Standard Televisions problems?
TV Sony KV 20EXR20
Necesito su colaboraci?n con... Answer This...
I HAVE A SONY TV 36 INCH
all i get is static (noise) no... Answer This...
TV Cable connector issues, Evil...
The TV itself is good as new,... Answer This...
TV keeps turning off
Hi my 42 in JVC keeps cutting... Answer This...
Toshiba 30HF66 30" TV
Black Screen
I just bought a Toshiba 30HF66... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
