Question about Kenmore 93042 Gas Dryer
No heat My problem was like the last person , But I seem to have heard something loose on the front bottom. Still no heat, but the heat has returned the next time I turned it on. Now Im back to no heat. Are the fuses in front? Is the back panel come off easy or can I get to the front side.
  • 625 Answers
There's no fuses on the unit. the cord connects to the control panel, the motor and the gas controller. you may need to remove the door and some screws holding the front panel in place. the panel will come forward and there may be some wires to disconnect for the light. the panel bottom has two tangs and notches they fit into. on the right bottom is the burner - check to see if anything is loose in the burner tube. maybe there's some loose change inside the drum or the blower housing. check the klixon thermostats on the burner and blower housing. the flame sensor may be loose
Posted on Aug 24, 2007
Packard bell notebook screen problem?
If hitting it seems to remedy the problem, I would say you probably have a loose cable somewhere. Either the Video Cable that is at the top behind the screen is loose or the LCD Inverter at the bottom of the screen (has 2 cable in it) is loose.
Mar 28, 2012 | Computers & Internet
I have a 2000 SL2 Saturn car- stick shift - I heard something "loose" under my car, it looks to be the heat shield - what are the chances it could be just a loose bolt? is it easy to fix...
I have owned 4 saturns, and sundry other cars. The heat shields are made of very thin metals and are riveted or spotted on. Myself I have done enough business at a local repair shop that they will put it up on the lift, let me tear it out and throw it away. Takes just a few minutes and being up on a lift is faster and easier than trying to tear it out from the side or just up on a jack. I have never seen a bad side effect of loosing them, nor do my floor boards seem warm. If you ever walked or biked much on heavily used roads you would note these things are laying all over the place, crushed flat. There is generally a large shield riveted to the bottom of the car, and another attached around the outside of the converter. You have an 02 and it is time to replace the converter.
Mar 15, 2011 | Saturn SL2 Cars & Trucks
Hello, I have a whirlpool duet washer, modelwfw9200sq. It is leaking. We had a repair person fix this last year ( just a small rubber tube comes loose) Can you tell me again where this was located on...
Front - bottom. You must remove the front kick panel to view.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 28, 2010 | Whirlpool WFW9200S Front Load Washer
Water leaking from underneath the front of the washer..
It could be a seal on the bottom of the tub or a loose or damaged hose where it pumps out. It could also be a loose hose on the water level switch. Remove the front and run it to check it out.
I believe you need to pry up slightly on the top and reach through the gap with a small screwdriver and press on the clips on either side to release the top and lift the top. Then there are two screws that hold the front to the sides and you should be able to lift the front off. Good luck.
Mar 07, 2010 | GE Profile WPRE6100G Top Load Washer
Cooling system faulty
Yes.
Check the return hose
Good luck.
Rate this please.
Apr 27, 2009 | 2000 Renault Sportwagon
Thump noise in front end
Have your CV joints inspect.
Mar 21, 2009 | 1999 Buick Century
Boot of the front loader washer
not nessacerily, the bopot off would create leaks not noise, you can remove the lower aceess panel(3 screws across the bottom of unit) and have a look inperhaps one or more of the suspension/shock absorbers) has let loose
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No color when turned on, after a while it color returns.
This is a cold solder joint in the signal section of the set. After it heats up, that problem area conducts better. Have an experienced electronic person reflow some solder on the board.
Feb 02, 2009 | Toshiba 32AF43 32" TV
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Kenmore 93042 Gas Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
