Maxent MX-50X1 50 in. Plasma Television Logo
A
Anonymous Posted on Jun 06, 2013
Buttons wont work
My mx5020HPM maxtent 50" plasma turns on, but is not responsive to any button presses. The power button wont even work. When the TV turns on it does flicker, and displays vertical lines for about 30 seconds. Any idea what I can do to fix?
5 Related Answers
Anonymous
  • Posted on Nov 02, 2008
SOURCE: Maxent 50" plasma problem
We seem to have had the same problem. Green light keeps blinking but will not turn set on or off. I unplugged the set for a few minutes, plugged back in and works fine but will happen from time to time for no reason.
Anonymous
  • 39 Answers
  • Posted on May 19, 2009
SOURCE: maxent plasma tv is showing only vertical lines.
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
Anonymous
  • 1015 Answers
  • Posted on Sep 04, 2009
SOURCE: Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
kriegen69
  • 121 Answers
  • Posted on Oct 28, 2009
SOURCE: 50" Maxent Plasma
you need to have a licenced repair tech come look at it sounds like the inverter is going out its kinda likea ballast for florecent lights
Anonymous
  • 14 Answers
  • Posted on Nov 16, 2009
SOURCE: I have a Maxent 42 inch plasma.When you turn it
What is the Product Name or Model number of your Maxent 42" Plasma TV? If it is a MX-42X3, Model # P420542HM8, I think I can help you. I have encountered this exact same problem with 2 Maxent MX-42X3 Plasma TV's. I found that C766, a 220uF, 16V surface-mount electrolytic capacitor on the main board is bad. This capacitor is located just to the left of the green multi-fin processor heat sink. This capacitor will test good using capacitor meter or an ESR meter, but if you spray it with Freeze-It with the power on, you will find out that this is the problem! To get it out, I found I had to remove the little 10uF 16V surface-mount capacitor just to the left of it. I then replaced these 2 capacitors with regular (radial), high-temperature, low-ESR capacitors. I cut the leads short, and bent the ends out just a little bit so you can solder them back onto the surface-mount pads. You can get these parts from Digi-Key Corp. I used Digi-Key part # P12383-ND ($0.32) for the 220uF capacitor, and P11212-ND ($0.30) for the 10uF capacitor. Both of these capacitors are rated for 25V and high temperature, so they won't go bad again. You can purchase surface mount capacitors there too, but I find them very difficult to solder back into those locations due to the tight placement of other capacitors in that area. If you're not an expert in soldering, I suggest you take the main board to a qualified electronic technician, and let him do it. But you better put the board in an anti-static bag before you take it anywhere! Hope this helps!
TV POWERS ON NO PICTURE
I had the same thing happen to my Samsung 46" led TV. It was a compassitor. We called around to TV repair guys cause we didn't have a lot of money. One of the guys came out and fixed it for $50 on the side.
Buttons on TV suddenly not responsive
If they are actual buttons check to see if one is stuck. Listen for a click on each button while it is turned off so you can hear it and feel it. Another possibility could be when you moved it around somehow the internal cable that connects the buttons to a connector has slipped out or just has a bad connection. Would require you to take the bezel off to see if the internal connections are ok. Not sure what else to suggest. At least the remote works.
Toshiba Plasma TV 50HP95 while watching TV screen went black and power light started blinking. No response from remote or buttons on the side of the unit. TV is approx. 7 yrs old.
Blinking of the power button denotes an internal circuit fault. If you wish to get more about the blinking codes to Samsung TVs, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option
My hp tv wont turn on
hi it sounds like your plasma has gone in stand by mode look on youtube will tell you all about stand by type in how to fix and tv make model stuck in stand by more than likely capacitors blown if your not any good soldering boards id phone tv guy out but if you are then youtube it hope this hopes
1helpful
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Samsung 50" Plasma TV no response to remote ctrl & buttons
No need to exchange the Logic Board.
Need to exchange the IR modue.
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Picture gets hung
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
50 in plasma buttons not working
The micro may have become latched - - try unplugging the unit for about 15 minutes. Then plug it back in and see if the functions are restored..
Bill
Top Maxent Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
