Question about Vivitar ViviCam 5100 Digital Camera
Camera says its conected, program says its not
I have windows 98, when I installed the software on the pc and pluged in the camera the camera states its connected to the pc and the pc says theres no driver. it worked fine before, is there anothere driver I need?
    Brigadier General:
  • 6,966 Answers
Hi, You can try booting your Win98 PC with the camera already connected to the USB. Sometimes 98 has a hardtime detecting if and when a USB device is connected to it when it is already running. By booting with it already connected, 98 at the onset sees it and boots with all the needed support files. Further, by booting with the camera already connected, you can verify if drivers are really needed since 98 will auto detect with "New Hardware Found" message. It might just be that you have to reinstall the drivers all over again. Hope this be of some help to you. Pls post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 19, 2007
SOURCE:
I have my camera pluged in and the drivers are all instaled. I got a message that the camera was ready to use but i cant find the camera software that allows me to open the program and take pics.
Hi skeeter2552,
I have looked into your problem and have found the following.
I managed to find the manual to your Webcam here:
http://www.amazon.com/Veo-Stingray-Web-camera-color/dp/B00006B9YB
According to the manual the Webcam originally came with a CD-ROM which had the drivers for Microsoft Windows 98, 98SE, Me, or 2000. It also had software called 'The Veo Stingray Suite' which enabled capture of still images and video etc.
If you can find the CD-ROM and you have a later version of Windows than the above, then it may be possible to use the Veo Stingray Suite in compatability mode, however I'm not sure if that will work.
As the drivers have installed and you had a message that the Camera was ready to use then this is a good start. As your camera is on a USB port then most up-to-date software should recognize it.
For example if you have Windows Movie Maker on windows 7, there is a webcam capture button for recording video. You will probably find that Software like Skype will also see it okay. Also you could look for Freeware for webcams but as always check for Viruses etc.
I hope this has been helpful.
Kind Regards
mparkyn
Jul 27, 2011 | Veo Stingray
I have a pc pro camera with create and share software it is for windows 98 i now have a computer with windows xp is there software to make it useable
Try downloading the windows 98 software with a shortcut on the desktop
Right click on the desktop icon and select 'Properties'
Select 'Compatibility' tab
Check the box 'Run this program in compatibility mode for:'
Select Windows 98 from the dropdown menu
Click 'Apply' and 'OK'
By trial and error check the 'Settings' boxes as required. Starting with visual themes.
Mar 22, 2010 | Intel Pro PC Camera CS430 Webcam
I purchased intel easy pca camera while my system has windows 98. I have now upgraded the software to windows xp. When i tried to install the intel create & share software, i could not install it. Is...
The only thing you can try is windows update. Go to start, program, windows update, run the update and look for a hardware update in the left column, make sure the web cam is pluged in and turn on first.
Good luck.
Dec 20, 2009 | Intel Easy PC Camera Webcam
Sotware issue
Please give m a Intel Deluxe PC Camera CS330 Webcam Installation Software and Driver
Regards
Lund
Oct 13, 2008 | Intel Deluxe PC Camera CS330 Webcam
Connection between camera and computer
What operating system are you using? Is you camera connected via USB? Have you tried using another USB port? Did you make sure to install the software before plugging in your camera?
Generally if you are running Windows 98, you will need to reboot after installing the software to even have a chance of the camera being recognized correctly.
If you are running Windows 2000, XP or Vista, the camera should be recognized and a driver installed or searched for from the CD software you installed before plugging in the camera.
Sometimes if you plug in the camera first without installing the software, the PC finds a new device with no driver. You can see this by going to Control Panel -> System -> Hardware -> Device Manager and you should see and exclamation on a device in the list. You need to remove this item and reboot your PC.
Now install the software first and when the install is done, then plug in your camera. Generally this works out pretty well.
Apr 29, 2008 | Canon PowerShot A80 Digital Camera
WEBCAM PROBLEMS
Is another program trying to use the camera in whatever picture program you are using? windows 98 doesn't have built in photo taking software, so check the settings of what ever program you are using to make sure it is "looking" for the correct camera, if you can read korean handuri is a great solution.
windows 98 is no longer supported for microsoft, so your best solution would be to upgrade to a XP.
Mar 03, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
I want to download pictures into my comouter
Generally if you are running WIndows 98, you will need to reboot after installing the software to even have a chance of the camera being recognized correctly.
Dec 16, 2007 | Canon PowerShot SD1000 Digital Camera
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Vivitar ViviCam 5100 Digital Camera Logo
41 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
