I have changed the fuse in the plug. It seems as there is no power getting to the Tv. There is no sound or lights operating. It's totally dead!! Is something blown inside the TV?
-   I have a 6 moths old song bravia, its wont switch on and i have changed fuse and changed to a different plug and it still wont work? any suggestions!-   orla1024
Try using a different wall plug one you know that works run an extension cord if you have to check it. Lastly are your wall plugs grounded 3 prong plugs? The old fashion plugs with 2 prongs are not sufficiently grounded and that may be your problem and you would need an electrician for that. Otherwise you may have a defective tv. BTW how did you change the fuse in the plug? Are you talking about the breaker box?If so you probably do have a grounding problem.
Was this helpful?
Yes
No
Popular Solutions for Sony BRAVIA KDL-40S2000 40 in.
Sony BRAVIA KDL-40S2000 40 in. HDTV LCD Television
Our 46 in KDL-46XBR2 turns on, but the screen is just black. No sound, display, nothing. Have...
(More)
Our 46 in KDL-46XBR2 turns on, but the screen is just black. No sound, display, nothing. Have unplugged, no difference.
Sony Bravia makes popping noise when one commercial ends and a new one begins. Does 't happen all...
(More)
Sony Bravia makes popping noise when one commercial ends and a new one begins. Does 't happen all the time. It happens more at night than during the day. Cable is plugged directly into wall (no box). It is very annoying, I'm thinking I should take it back it's only 2 weeks old and has done it since I got it. Sony had me reset my tv to factory settings and it worked for 1 day now we are back to square one.
when using my sky+ remote with my new sony bravia 40" lcd tv, it will change channels ok, but...
(More)
when using my sky+ remote with my new sony bravia 40" lcd tv, it will change channels ok, but won,t change the volume, or switch tv on or off. do i need a code to make the remote compatable with the tv.
